Internet Setup / Wiring - Beyond.ca - Car Forums
Results 1 to 20 of 28
Thread: Internet Setup / Wiring
    G05
    Default Internet Setup / Wiring
    Ok. so in the process of building a new place.
    Tell me what I should plan for to have the best coverage & connectivity for internet, sound system, security etc.
    There was another thread about WAP's. So would you just have lots of wiring to the rooms and hook up a switch to the Shaw/Telus modem or is there a better solution to have the most devices hardwired? I'm assuming I should add some WAP's locations for all the devices that I can't hardwire?
    Feel free to add anything else you think would be valuable.
    Ya want lotsa wirez bro. Wires cheap when building. Minimum 2x cat6 to every location you might out a computer or a tv, and 1 in every other room.
    UniFi is the prosumer favourite, nearly enterprise grade shit for not unaffordable prices.
    Actually we use a lot of UniFi in our enterprise network at work. Good shit.
    If I had an opportunity to build from scratch, here’s the list of things I would do.
    Dual Cat6 to every room. Map out where access points would go in the ceiling, cat6 there. Make sure garage has an access point mapped, as cars move to ota updates via WiFi.
    For the alarm wire all my doors for sensors. Wire for motion sensor locations.
    Wire DC power to all the window sills for powered blinds.
    Speakers, every tv area wired for atmos. 7.6.2 for home theater, 5.4.2 for living areas, 5.2.1 for master bedroom. 2 ceiling speakers in showers, 2 for all separate baths, 2 in each room. Separate from anything with atmos.
    Might be overkill but it’s a hell of a lot cheaper pre wiring everything now than later. Atmos is a little tricky as speaker positions are dictated by how many speakers you want in total, I’d go for a lower speaker setup in anything other than home theater as the equipment to power them takes a lot of space and more difficult to hide/heat manage. Anything more than 9 channels you’ll need a lot of space to hide the equipment.
    ^ yea this.
    Wires it to high hell now - but make SURE they are labelled AND sealed, as I've come back to wires after the various trades have left and I could read sweet fuck all on them. Nothing like retracing again.
    Get a proper wall mounted rack, or shelf, for the equipment. MAKE SURE if its a closet, that it has EXHAUST/VENTILATION.
    but
    Shaw/Telus modems should be put in BRIDGE MODE - get your own router and UNIFI WAP (as mentioned). I'm particular to their higher end routers for home use - not quite USG - but something a bit higher end like the Edgerouter 12 for eg.
    For routers, you can go baller and just unifi everything and configure all in 1 place. I have better places to spend my money, so I’m using a $130 asus router with Merlin firmware that has enough power to easily pass through gigabit of traffic, while managing individual devices on the network for VPN to get my US TV.
    But those are much later decisions down the road.
    Big savings going with that Asus
    https://ca.store.ui.com/collections/...curity-gateway
    Keep an eye out on Kijiji or ERA. I got a hold of a 24 port Aruba S2500 switch with SFP ports for the sweet 10Gbe connections for like $80
    Haha fair. There are other reasons too, such as unifi’s complexity in managing single device vpn. I believe poe switches the price gap is big as well.
    They are actually getting way better by stratifying their lineup more. No need to pay for features none of us will ever use.
    35 bucks for a 5 port switch, powered by POE or USB c ( I use this in my office) https://ca.store.ui.com/collections/.../usw-flex-mini
    130 bucks for 5 port POE switch ( powered by Poe if your switch can handle the power load)https://ca.store.ui.com/collections/...ducts/usw-flex
    260 bucks to go to 16 ports all POE https://ca.store.ui.com/collections/...sw-lite-16-poe
    We can’t all be @Buster and go with https://ca.store.ui.com/collections/...usw-pro-48-poe
    Honestly there isn’t a ton of reason NOT to go with a full UniFi setup in 2021, and we should see some good things in their WAP lineup this year.
    Been reading some interesting threads on the UDM pro, guys getting dockerrunning on it and building dedicated pihole on it etc. 2020 UDM rollout was a mess I’ll admit but I think the hardware has a ton of unutilized potential.
    Anyway that’s my UniFi plug for the day lol
    Ya I went with a 26 port poe for $250.
    G05
    how many wireless AP would be enough for a 2 storey plus basement home?
    would changing the your telus/shaw modem to bridge mode make a significant difference? what happens if you connected the poe switch directly to the shaw/telus modem?
    1 AP per floor is a good minimum. Probably plenty for most users unless you have a lot of square footage, say 1000-1200 or less per floor. Outdoors and garage is a whole other can of worms. I have 1AP per floor in 1,400 sqft per level and could really use more. This assumes AP in center of floor which is rarely an option, if you stick it in one. Corner good luck having signal in the other corner.
    Bridge mode just allows you to use a third party router, you can go ahead and just hook up a switch to the gateway but don’t expect it to make ice cream from poop, if you have more than a dozen devices on the network the garbage they give you just won’t hold up. If you are going to build out a network don’t skimp out on a new router and use the Shaw/Telus boxes for as little as possible.
    Quote Originally Posted by s2k_boi View Post
    2 minimun APs in the average house for light use.
    The ISP routers are a joke, wifi on top of them is even worse.
    You will, in most cases have a noticeable improvement with multiple user devices. Yes, you can get by if you lack cash, but it will always limit the true speed of the connections.
    It’s always hard to future proof, but at least we know WiFi 6 supports 6ghz, and as wireless moves up the spectrum, usable range will continue to drop. I feel like the 1 per floor is no longer a bare minimum as we move higher up the spectrum. I also don’t know what wireless usage and density will look like in the future. Even if you’re not WFH on video calls, maybe there will be a need for bandwidth down the line for mobile devices that equals or exceeds that sort of usage. These 2 factors literally point to a high density AP model.
    G05
    I'm finding it hard to decide on what POE switch too. This one seems like a decent deal but it's at 190w. so depending on how many AP's and how my security system eats up the power usage.... Would this be sufficient or should I be investing in something a bit bigger at 380w? I'm open to suggestions on equipment too.
    https://www.amazon.ca/NETGEAR-24-Por...s%2C196&sr=8-5
    Guessing this router should be better than my ISP?
    https://www.amazon.ca/dp/B01N08LPPP?...agonelinkca-20
    or this one https://www.amazon.ca/Dual-Band-Supe...9&sr=8-45&th=1
    Which AP's would you guys recommend?
    That’s the exact switch I have, although I got it a bit cheaper. Anyways 6 APs on it, it’s using 20W.
    Here is what I would suggest for a 'mid range', setup for router + 2 APs (similar to what I deploy to clients homes and small businesses).
    Edge Router 12
    https://www.amazon.ca/Ubiquiti-Netwo...tronics&sr=1-1
    Unifi AP - LR PRO edition (x2)
    https://www.amazon.ca/Ubiquiti-Netwo...0949364&sr=8-4
    True. My parents did a down-to-the-studs reno on their 50's house, and my dad used me for slave labour to pull many thousands of feet. Minimum 1 coax, 2 pairs speaker wire, 2 cat6 to every room (most have more than this) and other applicable locations, like entrances, as well as attached and detached garage. Also wire to all windows for automated blinds, shutters, etc. It was a miserable job.
    And here's the rats nest/progress pic. Many of these are spares (for now):
    Conduit from the basement to the attic in case you want to run more cables of any kind.
  1. Replies: 38
    Latest Threads: 07-04-2018, 03:49 PM
  2. TUNGSTEN T-3 Does it have wireless setup to pick up internet?
    By harley11 in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-08-2006, 04:36 PM
  3. Check out my internet setup
    By camaro in forum General
    Latest Threads: 11-23-2005, 09:33 PM
  4. How to setup a password so people can't steal wireless internet
    By Redlyne_mr2 in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-27-2005, 01:59 PM
  5. Need Some Wiring Help Please....*Wiring GURUs Enter Here!*
    By Weapon_R in forum In Car Entertainment / Electronics
    Latest Threads: 04-21-2005, 06:38 PM
