Should You Boost A Frozen Battery? - Page 2 - Beyond.ca - Car Forums
Page 2 of 5 FirstFirst 1 2 3 ... LastLast
Results 21 to 40 of 82
Thread: Should You Boost A Frozen Battery?
    Sigh. Bring it inside and let it warm up for 6-8 hours BEFORE you start charging it. Then change it, somewhere with good airflow. Then just drive straight to the parts store to trade it in on a new one. If your battery wasn't fucked when this thread was started, it probably is now.
    Its shocking you didn't take care of this already.
    Sigh...
    Oct 2013
    Blackfalds aka north RD, AB
    Bikes.Car.Truck
    You might find out fast if it’s totally frozen by boosting it...
    It isn't frozen. He has power to all electronics still. Just not enough to turn the engine over.
    Looking around
    Wondering what became
    Of what I once knew
    Thaco's Avatar
    Rage2
    that was almost a week ago... it's likely toast by now if he didn't deal with it then.
    User title molested by Rage2.
    Nov 2005
    2015 Hyundai Veloster
    I literally leave my house once a month and that's only for emergencies or appointments, I want to keep my exposure down and I work from home so it's no big deal. I just got into a disagreement with a F350 last month so I need to bring my car to the body shop on Wednesdsay, otherwise I'd wait until the spring to deal with it. I also have 3 cars so this wasn't such a high priority for me.
    The battery's in my basement now, I finally got it out. When I went out to get it there wasn't any power at all, I actually had to use the key in the door like some sort of neanderthal. I'll wait until tonight and then either put the charger on it or use the CTEK trickle charger from the Porsche. I'm not sure yet which would be better.
    Originally posted by Go4Long
    or else what? you'll turn on the caps lock?
    you do realize this is the internet right? lol
    Originally posted by rob the knob
    mar, you are good guy at heart
    you must realize your limitations
    then you will be happy if you fine place in live
    Originally posted by blitz
    Jesus man, I know you like Transformers, but you need to get out more. No one should get this upset over a movie based on children's toys.
    Well, you've taken every precaution to ensure this battery is damaged at this point. So charge it with whatever you want and just plan on replacing it soon.
    Oct 2013
    Bikes.Car.Truck
    What kind/brand of battery is it? When you took it out, did you here any sloshing sounds or is it a totally frozen block? Also, do you have a multimeter?
    Looking around
    Of what I once knew
    You should potato.
    Mar’s time is very valuable.
    I suggest a couple of lemons to really get that trickle going.
    Quote Originally Posted by Mar View Post
    Now that you've done a Mar - use the CTEK as it will reject a bad battery immediately for any charging. If it DOES accept it, do the lowest charge level possible. I rescued my wifes completely dead batter (interior map light left on) this way, over a 48 hour period - far better for it than a quick charge.
    Jul 2006
    Victoria Park
    Seriously, some times I wonder how Mar can even get through life. Seems like a sitcom.
    Got into a "disagreement" with a F350... Nice, lol.
    Thaco's Avatar
    Rage2
    I just dont get how someone can come on here and ask for advice and be told by multiple poeple how to deal with it and that it's probably ok because there's a little power but if it freeze solid you will need a new $150+ battery.... and then ignore that advice for 5 days of arctic temperatures causing it to be totally borked....
    Nov 2005
    Quote Originally Posted by Thaco View Post
    Probably okay.....I didn't know for sure if it was already frozen. I only knew it, "probably wasn't frozen.'
    Thaco's Avatar
    Rage2
    you said the lights came on and it unlocked, that means it had power, that means it wasnt frozen solid.
    Nov 2005
    Here's the battery. I hooked up both clamps to the terminals, is this acceptable? Normally I know that's bad and one is supposed to go to the frame.
    And also the CTEK, I set it to RECOND hoping that will help.
    Can it be partially frozen? I admit, I was too scared. I had to know for sure if it could safely be started in that state.
    All good Mar. That charger, if I'm reading it right, is good for 5 amps, which is plenty to recharge overnight.
    Thaco's Avatar
    Rage2
    you normally use the frame to eliminate a bad ground to the starter when boosting, also it reduces the chance of spark above the battery where gases can accumulate and ignite. Here you're trying to charge the battery, so direct to the battery is best.
    Nov 2005
    All 7 stages of CTEK charge complete and the battery is back in the car. Thanks, everyone.
    well thank goodness, now just put everything about batteries out of your mind and YOLO on good sir.
  1. What kind of battery should I get? where should I buy it?
    By gt2871r in forum General Car/Bike Talk
    Latest Threads: 05-23-2011, 06:03 PM
  2. Frozen Battery
    By Deetz in forum General Car/Bike Talk
    Latest Threads: 01-18-2009, 06:00 PM
  3. 5 things you SHOULD and SHOULD NOT do when pulled over
    By HiSpec in forum General Car/Bike Talk
    Latest Threads: 05-21-2008, 09:21 AM
  4. my windows are frozen, and i mean FROZEN
    By azndragon1234 in forum General
    Latest Threads: 11-27-2006, 03:21 PM
  5. How do you boost a frozen car?
    By Speed_RaSiR in forum General Car/Bike Talk
    Latest Threads: 02-01-2004, 09:57 PM
