Basement Design Consideration - Beyond.ca - Car Forums
Results 1 to 20 of 20
Thread: Basement Design Consideration
    Apr 2003
    WK2
    Default Basement Design Consideration
    There's been a few basement development / entertainment threads around that I've been able to get some info on, but instead of hi-jacking those, thought I'd start my own.
    Looking to develop the basement this winter. Had the drawings completed, and the building permit approved earlier this week. Will be starting framing soon, but not sure how to approach this rec room and TV area.
    Name:  Screen Shot 2020-11-19 at 3.28.15 PM.jpg
    The TV will be going on the east wall, where the DATA marking is. Based on the dimensions of the room:
    1. Will a 75" TV be sufficient? Will be a darker room, so thinking of the Sony 900H
    2. Flipping back and forth between Sonos Arc and monoprice in wall speakers. Looking for a clean / minimalistic setup, but is putting in wall speakers in external wall recomended?
    3. Will anything above a 5.1 be overkill for the size of the room? The nerd in me would love to setup Atmos, but not sure there's space in the ceiling for proper spacing?
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Looks like you have more than enough space for ceiling speakers, according to the Dolby Atmos design guide you want them basically right on top of where the couch is going to be.
    https://www.dolby.com/about/support/...r-setup-guide/
    Canyonero
    Personally I would not consider in-wall speakers for an external wall. Wall-mounted soundbar or front channels are plenty clean enough IMO, and you wouldn't need to interrupt a vapour barrier and risk condensation ruining your speakers.
    You are going to want WAY MORE than four pot lights. I have eleven 4" LED pancake lights in a 20'x14' basement rec room. You do have a window in the room which will help, but I'd plan for minimum six, probably closer 8-9 lights. Put them on a dimmer. Mind the maximum load rating of the dimmer itself. Perhaps onsider creating two "zones", one around the east wall / entertainment area (dimmed) and one behind where the couch will go.
    The manufacturer of the lights should offer a "throw distance" / illumination cone drawing you can use to more appropriately space your lights.
    For a 75" tv, optimum distance is 10 -1/2' away, so you're good there, assuming you leave a path between the back of the couch and the bar.
    Canyonero
    Is the shelf indicated underneath the stairs a place you're considering an amplifier/data cabinet? If you want truly minimalistic you need to have an equipment rack somewhere out of sight but wired to your TV or projector.
    It's probably worth running a conduit out to the ceiling where a projector might go, even if you have no intention of using one yourself.
    One regret I have from finishing our basement last year was not putting pot lights into the bedrooms/office. I just went for the traditional one-overhead fixture and it's kind of dark. If you have any intention of using the space regularly, it's almost impossible to have too much lighting.
    I say almost because I definitely put too might light into a small corridor with a lower ceiling due to a bulkhead and it's obnoxiously bright.
    Otherwise, my favorite feature of our basement was the ample storage/workshop space we put in. With a detached garage, our basement has become the most secure place to store valuable items like bikes and tools.
    A lot of newly developed homes really are stingy on the storage/workshop space downstairs, which shows well when you walk through, but at least for our living needs, wouldn't be sufficient.
    May 2005
    2015 IS350 F Sport
    First thing that came to mind for me too. Better to have too many pots with a dimer than not enough.
    "if you disagree with my views are cannot adequately my criticism then ignore my posts." - Nusc
    Apr 2003
    WK2
    Ahh yes. Validation to spend money!
    You are going to want WAY MORE than four pot lights. I have eleven 4" LED pancake lights in a 20'x14' basement rec room. You do have a window in the room which will help, but I'd plan for minimum six, probably closer 8-9 lights. Put them on a dimmer. Mind the maximum load rating of the dimmer itself. Perhaps consider creating two "zones", one around the east wall / entertainment area (dimmed) and one behind where the couch will go.
    Thanks. Vapour barrier was my concern was well. I've toyed with the idea of creating an interior wall that goes against the east wall, to put wall speakers in, but then I'm losing another few inches from overall space. I also wondered if 4 lights was enough. 4 x 6" pancake lights were recommended, but adding more seems to be the safer bet.
    Thanks for the confirmation! Will want to make sure the walkway between the couch and bar is sufficient. Should i estimate about 4'?
    Underneath the stairs, I already have a 12U rack with my network equipment. Rack was planned to add in a receiver and maybe XBox for basement development. I do plan on running conduit to the back of the TV area, will just have to make sure there is space. Would creating the exterior wall with 2x6,s give me some more flexibility for putting conduit down the wall outside of the vapour barrier? Also wondering if i should just use 2" PVC for conduit versus some of the more expensive 'specific' low voltage products Ive seen available.
    We're developing basement to get a bit more usable room. A large closet in the basement bedroom will help with that, plus some more functional storage in the mechanical / furnace room.
    As a side note. Make sure those potlights aren't going to be directly above where you plan on putting couches/chairs. It's super annoying to have a light shining right above you.
    I'm 10ft away and I have an 85". I want to go bigger if it wasn't cost prohibitive.
    Real life footage of @rage2 watching tv
    As if I’m one to talk
    +1 on two overhead speakers for Atmos. Or even just rough in the wiring if you don't want to spend the money on the speakers now.
    Next time he upgradesName:  eyes-looking-different-directions-duane-syndrome.jpg
    Apr 2003
    WK2
    85" is getting in to the cost prohibitive realm for me I think. Primary viewing would be hockey (whenever it's back), and movies, which is why I'm leaning towards the Sony 900. I'll probably post in the TV recommendations thread once it comes time for that decision.
    Canyonero
    Quote Originally Posted by 94CoRd View Post
    I don't have much experience with the larger 4x6 pancake lights, but I could see how fewer of those would create an equivalent amount of light. Recommend just reading up on the manufacturer's recommendations in terms of light cone at your ceiling height.
    I'd just go with the biggest generic/cheap option you can find. I'd try to use something like 3" ABS or PVC, but obviously if you're having to furr down the ceiling or build a weird bulkhead, maybe you want to stay fairly small in diameter.
    He upgraded to a full head of hair and a beard?
    One of those is impossible by genes, and one hasn't existed in 25 years.
    Sep 2016
    Calgary, Ab
    2021 Zonda CRV
    When framing, consider how/where you would like to mount the TV. Height, angle and cables. I am personally not a fan of the tv being mounted so high.
    Don't just put in pot lights for the sake of it. As mentioned above, consider where you will put in sofa etc.
    Start with that type of light you would like and then work on they type of lights to fit that. Don't just think of ambient lighting, will you have enough light when you clean and vacuum the place for example?
    Those are my primary use cases too, with gaming being a 3rd. It's too bad Vizio pulled out of Canada, the Quantum X is really the best TV that's better than the 950H at the price of the 900H.
    I'd go for 4 in the ceiling, or at least pre wire/position for it. It's a pretty big difference between 2 and 4. I can only manage 2 in my setup because Atmos wasn't around back then, and the cost to rip up the ceiling to add more is ridiculous.
    The TV can never be big enough. I would've put a 65 in the bedroom but it won't fit on the dresser without hitting the ceiling.
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    If you're DIY'ing the low-voltage stuff, I highly recommend getting your cabling from Infinite Cables. They're actually cheaper than Primecables I find and their materials actually have the Canadian ratings on the jackets.
    Ceiling mount it!
    Apr 2003
    WK2
    900H will fit the bill thought right? Unless the 950 comes down drastically in price, it's a bit out of range for my budget and wanting to stick with a 75". I'll think about wiring for the additional speakers, but not looking to spend the additional monies required on the receiver end of things.
    Thank you. Will be doing all the low voltage stuff myself. Haven't used infinite cables before though.
  1. Basement Layout Design Help
    By cidley69 in forum Home and Garden
    Latest Threads: 09-22-2015, 11:10 AM
  2. Help design my basement
    By charlie2 in forum Home and Garden
    Latest Threads: 01-01-2013, 08:46 AM
  3. goodwill consideration by dealer?
    By gmoney82 in forum In Car Entertainment / Electronics
    Latest Threads: 07-14-2009, 08:58 AM
  4. For Your Consideration: The Gumpert Apollo
    By BlackFyre in forum General Car/Bike Talk
    Latest Threads: 01-09-2009, 04:47 PM
  5. rice consideration
    By sh0ko in forum General Car/Bike Talk
    Latest Threads: 01-10-2007, 11:03 AM
Tags for this Thread
