Finally upgraded my home wifi to something that works - managed wifi review - Page 36 - Beyond.ca - Car Forums
Page 36 of 51 FirstFirst ... 26 35 36 37 46 ... LastLast
Results 701 to 720 of 1002
Thread: Finally upgraded my home wifi to something that works - managed wifi review
  1. #701
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Thought I'd bump this, apparently the new UniFi Controller firmware is crazy buggy and brings back the broadcast storm problems that @rage2 was having.
  2. #702
    Youre talking about the cloud key setup? (and not the java based, Windows software that also acts as a controller)
  3. #703
    Two aspects to cloud key or UDM, Firmware in device itself. And controller software which is the same no matter where it’s hosted.
    I presume it’s the controller software that is causing issues he mentioned.
    That said, can’t say I have noticed anything.
  4. #704
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Yup, controller software. Here's a link, also seen a couple of Youtube videos pop up on my feed that say the same thing as well.
  5. #705
    Grimace
    Ran into an issue last week where I couldn't login locally (I am pretty sure I had the right login info) so I used the same login via the web view and then had to create a second admin to access locally. Anyone else run into this?
  6. #706
    06 S2000
    I just updated my docker container to 6.0.20. Goddamnit.
    My car sounds like shit.
  7. #707
    06 S2000
    Looks like 6.0.22 was released to try and address that.
    https://community.ui.com/releases/Un...1-df5eeee34695
  8. #708
    Okotoks North
    Any reason you guys upgrade to the latest version right away?
    Need to handle your networks like Ron Popeil would.
  9. #709
    Calgary/Alberta
    2022 X2M
    I can confirm that it does not fix it. And now my wifi retries are through the roof
    E .· ` ' / ·. F
    Your tears fuel me
  10. #710
    Quote Originally Posted by kenny View Post
    That pop up gets annoying lol.
    Strange that this is triggered by the controller though. I haven't upgraded. Controller software should be easy to downgrade no?
  11. #711
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    I don't unless there's something essential in the new firmware, or if something broke.
  12. #712
    06 S2000
    Because I hate myself. And a coworker mentioned it to me, so my only thought was "new toy!" Once I figure out which tag to use, I'll likely downgrade.
  13. #713
    Calgary/Alberta
    2022 X2M
    The new controller software is dog shit. I normally average under 10 in both anomalies and association failures a week. This is just from today. Yikes
    Name:  Screen Shot 2020-09-20 at 11.16.36 PM.jpg
    E .· ` ' / ·. F
    Your tears fuel me
  14. #714
    06 S2000
    My association failures calmed down, but I'm still seeing a ton of High Wifi Latency issues.
  15. #715
    I've been doing this for years, without issues. UNIFI updates were not like Windows Server updates in that they needed to be vetted prior to implementation (ie. whats it going to break?).
    Quote Originally Posted by Kavy View Post
    Yea this is bizarre, I am seeing it with my clients now as well. Im moving one client away from UNIFI completely.
    Its almost to the point that UNIFI is fucking things up deliberately - or having something forced upon them thats causing this.
    In no reality should 3-6 months of constant headaches be the norm.
  16. #716
    Title of thread: Something that works.
    Content of thread: Stuff that is a hassle to get working.
  17. #717
    Stuff that BECAME a hassle ..... ugh
  18. #718
    Up front hassle versus every day hassle.
    Pick which one you prefer.
  19. #719
    Just a quick update - was able to get my client and their ~35 WIFI devices more or less operational again.
    From a UNIFI forum user recommendation - I cranked up the power from CUSTOM (18 db) to HIGH and disabled RSSI completely (although I think it defaults to -90 db).
    Suddenly things started connecting and staying stable.
    I've used the POWER and RSSI settings in custom (adjusted) mode for years - so obviously there is something strange there with the updates that broke it.
    Not ideal, but works now.
  20. #720
    Calgary/Alberta
    2022 X2M
    In a home environment this would worry me. I have 3 APs and in reality 1 can cover my whole house (but I would have areas of poor reception) so I run low power on 2ghz and medium of 5ghz. Previous to this “software update” I was able to have near perfect hand offs and distribution of clients on each AP (14-12-15) with an RSSI of -75db. Cranking up the power would probably help the association issues but I imagine it would impact my handoff as well as have me fighting my own APs for interference. However my understanding is rudimentary at best so if I’m incorrect please chime in, I would love to fix this.
    E .· ` ' / ·. F
    Your tears fuel me
  1. Finally upgraded to a dual band DD-WRT router
    By WhippWhapp in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-04-2017, 10:49 AM
  2. FS: HP Procurve 1800-24G managed network switch
    By Smokem in forum Computer Hardware & Peripherals
    Latest Threads: 03-14-2012, 06:09 PM
  3. Managed Funds
    By cidley69 in forum Real Estate / Finance
    Latest Threads: 02-23-2012, 08:44 AM
  4. Something, something, something, Dark side
    By Tik-Tok in forum Entertainment
    Latest Threads: 12-27-2009, 08:15 PM
  5. FS: Netgear FSM726S L2 managed Switch
    By 02WhiteWs6 in forum Computer Hardware & Peripherals
    Latest Threads: 11-16-2007, 05:03 PM
