I'm trying to merge two divx (cd1/cd2 avi) files using VirtualDub but when I goto append the avi segment I get an error because the audio streams have two different sampling rates....what should I do?
Is there a different way to merge the files?
Extract the audio, merge them, then join it with the two video files in Virtualdub.
Thanks for the tip, should I be using TMPGEnc to extract the audio?
As replied from your PM, Virtualdub is able to extract audio via File -> Save WAV. Audicity will be a good program to edit audio files.
