hey,
i got a sub problem(kinda weird). my sub makes a loud rumble noise evertime my deck is off and never stops. can anyone help me with this? anyone experience this?
hey,
"God Rested On The 7th Day Cuz He Raced Me On The 6th"
maybe you have that problem because you used speaker wire for the whole install![]()
It's because you used speaker wire for every connection:
Speaker wire for the power
Speaker Wire for the ground
Speaker Wire for the High Level Output
Speaker wire for the remote wire
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
Does it still happen when your key is only turned to accessories and the motors off?
What's wrong with that? Wire is wire is wire. Unless you mean gauge sizeOriginally posted by Weapon_R
Why the fuck would you use speaker wire for power and ground????? Power wire isn't that expensive!
dude if you see this "install" you will understandOriginally posted by D'z Nutz
What's wrong with that? Wire is wire is wire. Unless you mean gauge size![]()
ahh once again![]()
wow this install sounds pretty shitty
haha yeah it does sound like ghetto installs inc(tm)
but it's probably a ground loop and you're hearing engine feedback
time to laugh when that speaker wire(16 gauge probably... haha) catches fire and burns the car down.
edit: uhm, if your deck is off, your amp should be off(unless you ghetto rigged a jumper wire for +12v remote...) and you shouldn't hear anything on your sub.
i'd recheck everything, and just MAYBE, just MAYBE install it properly.
