Anyone know an easier way to detect (pinpoint)a boost leak / vacuum then just randomly changing lines and couplers?
Any ideas would be great, I've been having a hell of a time looking for this boost / vacuum leak!! > <
- Rick
- Rick
I think I finally found a ride I like
Start car. Spray brake cleaner on the lines that you think might be leaking. If they are the idle will change.
I heard brake cleaner and ether is good substance to check leaks. So either or?
Ek9Max, was wondering if there was any tricks when spraying this stuff on... the can says flameable, anything to worry about?
The easy one is the brake cleaner or ether . It is pretty tame but may not find all leaks.
If you do a search on mr2oc for "noshoes boost leak tester"
you will find a thread on how to make a cap you shove in your intake and hook up to a compressor. I made one and it cost me about $10 with parts from Home Depot.
the best is to use carb cleaner and spray. water will not work on a vacuum leak but carb cleaner or break cleaner will. go apeshit in the area you suspect is leaking and you should find it.
I couldn't find the vacuum leak, so Im going to try to make the "the boost leak tester" once I recieve these 2 couplers i ordered from autodream.
Thanks
Check the hoses going to the power steering pump. They are notorious for falling off.
1988 Toyota Celica GT-Four
1994 Toyota Celica GT-Four WRC
Thanks, will have a look man
rick you dont have power steering.... I have a homemade leak tester for piper if you want to borrow it....
Yeah I didnt think I had power steering either, but was worth a shot to take a look. LOL!!
