anyone know if there's a usdm counterpart for the silvia clutch slave and master cylinder, apparently the 240's does not crossover according to nissan.
Do not listen to them, they are the same part. well they should be, the slave clyinder is for sure. and i'm sure the master is too, pretty damn sure. not sure about S13 to S14 parts.
the master is the same. both 240droptop and myself got our clutch master clyinders from a silvia.
Good to know, i need a new master mine is leaky, i only got like 10cm. of pedal travel.
~Braden
well actualy mine is a 240sx cylinder I bought it new remeber but yah it is the same but the slave dosent fit if I recall
Cheap 16 wheels for sale
http://forums.beyond.ca/st/256625/f-s-16x7-black-modenas-4-100-108-40/
anybody know if theres a crossover part then?Originally posted by 240droptop
the slave dosent fit if I recall, now im confused, anyone know for sure or no?Originally posted by dymz999
I know my stuff when it comes to these engines, part by part more a less. THEY ARE THE EXACT SAME, NOW STOP WORRYING!!!
http://www.courtesyparts.com/Merchan...de=30620-SR20T
no they're not, fitting for the line is on the side for the usdm ones and it's on the bottom for mineOriginally posted by crazydave
ah I got my sylindors mixed up agian. Of course it dosent fit its on the other side of the car on the sivias than on the 240s uness you get some custom lines bent
let me know if you want one, i got a few jdm ones laying around. (no slaves)
pm sent
problem solved, master cylinder no longer needed
