can anyone help me figure this out, im trying to figure out how you find the current and voltage for the the R values, when ur only givin the resistance values and voltage total. thanx
I think you find RT=R1+R2+R3+R4+R5 first.
Then for voltage of each R value i think you do VR1=R1/RT
and for current i think its I=V/R
ya i did that and found out my RT to be 60 ohms and then i found the current total to be 2 A. i just dont know how to get the voltage and current for the R values
Try the voltage divider rule to get the voltage. VR1=R1/RT*VT
I have no idea about the current, if you find out let me know.
awesome thanx, to find out the current u just go I=E/R
voltage
ya I=V/R is the correct way. i just got in the habbit of doin it the other way, once again thnx for the help i have a test tommorow and that was basically the only thing i couldent figure out
No problem manOriginally posted by pyro
RT isn't 60 ohm its 30.
RT=R5//(R1+((R2+R3)//R4))
// means they are in parallel.
R2+R3=60ohm
60//R4=15 ohm
15+R1=45ohm
R5//45=30ohm
RT=30ohm
VR1=160V
Vr2=26.6V
VR3=53.33V
VR4=80V
VR5=240V
Been awhile since I worked on parallel series circuit but pretty sure thats what it is.
weed is corect, that is a series parallel circuit.
I aint no junky.... I just keep it funky
power is p=ei in watts
yea i'll second what weed said. he's right that's what i got too. thanks for the little challange i'll have to remember that for when i go back to sait. good luck
alright i have some more problems. for the first one i need to find the voltage drops across each lamp. thanx
all the lamp resistance are the same. need to find the voltage drop across the lamps
i'm confused on what your asking. the second one you have 1and2 in parallel with 3 in parrallel with 4and 5.
so 1 and 2 in series, and 4 and 5 in series.
the first one says what the voltage is. and the second doesn't have a resistance.
ya i was really confused with these schematics i really have no idea whats going on. im just supposed to find the voltage drop across each lamp when the source voltage is 120 and all the lamps have a resistance of 240 ohms.
i forget how to do the first one.... i'll work on it i'll see if i can figure it out. by that time it will be too late. i know i did it before i just can't remember but i don't feel like doing it now that it's late sorry.
thats alright, thanx anyways
