Map Sensor - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Map Sensor
    Sep 2005
    TÜRKEY/ANKARA
    Default Map Sensor
    Hi friends ı have got some question about map sensor
    do the atmosferic cars use it?
    ı heared from the some forums and they said that some athmosferic cars used map sensor is it true?
    they give an example
    2001 206xs,106gti/saxo vts, 306gti,astra 1.6-1.4, civic vti toyota corolla and the others...
    I think it is not true the atmosferci cars use maff sensor
    please help me
    thanks
    emre
    Brocket
    B18C5 neon -|-y|>3 r
    by admosferic you mean "naturally aspirated"? in that case i've seen them with both MAP and MAFF sensors, those most new cars seem to use MAP sensors. what do you drive?
    Sep 2005
    TÜRKEY/ANKARA
    ı think the athmosferic cars used maff and ı never seen map sensor in athmosferic cars for examla 1 bar map sensor ıs it use 0.5 for pressure and use the other 0.5 for vacuum?it is not logical for me
    what is your ideas about this subject?
    thanks emre
    MAP sensors are used in all kinds of NA cars, like Honda. All it does is convert the pressure in the intake manifold to a voltage signal for the ECU. I think they're a more robust design than the MAF sensors found in Nissans.
    Splitting a 1 bar map sensor in half for vacuum and boost doesn't make any sense. That would make it into a 0.5 bar map sensor.
    Sep 2005
    TÜRKEY/ANKARA
    but you said that used in all cars ı dont see in athmosferic cars they measure the pressure in the athmosferic cars there arent any presura there are onl vacuum so they use maff sensor it is very usefull for vacuum theother side of map sensor is ıt can be measure the vacuum for example 3 bar map sensor measures 2 bar presure and 1 bar vacuum
    ı have got another question to you dear friend
    about peugeout 307 1,6
    is pegeout 307 1,6 uses map sensor??
    please help me
    thanks
    emre
    Jul 2002
    944 535xi F250
    MAP sensors measure absolute pressure so just like air pressure is 101.kpa or 1 bar. A 1 bar sensor measures up to atmosphic pressure. a 2 bar sensor measures up 1 bar overpressure and a 3 bar measures up to 2 bar overpressure
    ninja trainers motto
    always be able to kill your students
    Sep 2005
    TÜRKEY/ANKARA
    thanks friends
  1. GM 3bar MAP sensor
    By rice_eater in forum Forced Induction Talk
    Latest Threads: 04-07-2005, 01:40 AM
  2. How about map sensor?
    By trackerthrasher in forum Forced Induction Talk
    Latest Threads: 02-08-2005, 01:16 PM
  3. 1988 Prelude Si MAP sensor
    By Preludacris____ in forum Mechanical
    Latest Threads: 03-02-2004, 06:20 PM
  4. WTB: GM 3bar map sensor
    By buh_buh in forum Automotive Parts
    Latest Threads: 01-09-2004, 07:21 PM
  5. FS: GM 3bar Map sensor.
    By legendboy in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-21-2002, 05:44 PM
