Turbo leaking oil out the oil feed.. a Lot of oil - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Turbo leaking oil out the oil feed.. a Lot of oil
    b_t's Avatar
    b_t is offline b_t is a huge nag (2019 friendly)
    Jun 2005
    Mordhaus
    FC3S 10AE / Tacoma
    Default Turbo leaking oil out the oil feed.. a Lot of oil
    Alright I took my turbo out yesterday, just to replace some gaskets and to stop a leak I had on top of the turbo in the feed line (get rid of the shitty banjo bolt thing in there and replace it with a proper flange), and to add a real gasket to the return and replace my -4AN SS feed line (since I set the old one on fire, don't ask).
    All that went well enough, but now, the oil is leaking a prodigous amount of oil out the feed. Like, three times as much as before. It is coming up where the -4AN->1/4" NPT elbow is (I had teflon paste on all those threads), up through the two bolts holding the flange on, and out the sides of the gasket, it is leaking oil into the turbine section so it is burning a bunch as well, and oil is coming out the bottom where the NPT->-10AN fitting is too. What the fuck happened?
    I drove around with that old slow leak on the feed for about two months and never had a problem like this. Is it possible that when my old feedline got torched, something got into the turbo? Visually the line was only bad in the middle, it was totally fine towards the turbo side, and I disconnected it right away and never actually put any oil through it to the turbo. The old line still had clean oil in it too. The return line isn't kinked or anything, it worked fine for about two months, I'm going to double check it tomorrow but I don't think that would be my problem. If there is a blockage somewhere in the turbo, how do I clear it out?
    edit: other things that might be important, when it was reinstalled, the turbo had no turbine shaft play, only slight compressor shaft play, and trace amounts of oil on the inside of the compressor housing and charge pipes
    edit2: well since the oil inlet whole is threaded I could always ditch the flange and put the other elbow I got straight into it, but that doesn't look as good, plus the fuckin flange shouldn't leak anyway. What the hell happened?
    May 2003
    DC4, CB750, CB360t
    Is there a gasket on the inlet flange? maybe the flange is warped a bit.
    b_t's Avatar
    Jun 2005
    Mordhaus
    FC3S 10AE / Tacoma
    Yeah there is a gasket in it. I am going to check my return line again today, there might be something blocking it since this is what happened way back when I first got this installed and had a shitty return line with a dip in it that got oil all backed up into the turbo
    6.7 CUMMINS
    The fitting might be cracked?
    b_t's Avatar
    Jun 2005
    Mordhaus
    FC3S 10AE / Tacoma
    Naw, figured out what it was... gunk from my little oil line fire stuck right at the end of the return line -10AN hose end. cleared that out, then ran the car with the turbo just dumping oil into a bucket for awhile with no exhaust running through it to be sure. Its working fine now
    corey I'll be phoning you about that wastegate sooner or later... mounting it will be a bitch though, there is hardly any room, prolly going to have to put it on an elbow so its parallel to the manifold..
    Jul 2002
    944 535xi F250
    why not go back to the "shitty" banjo fitting ? they can flow about 3x as much as the pre WWII AN series and SAE NPT. you probably just needed fresh seal rings and now a new feed line.
    ninja trainers motto
    always be able to kill your students
    b_t's Avatar
    Jun 2005
    Mordhaus
    FC3S 10AE / Tacoma
    I don't think flow is that big of an issue here, I have a pressure restrictor at the feed now so this new fitting will do just fine, but I'm mostly just keeping it because it looks so damn good
    Jul 2002
    944 535xi F250
    reliability is also a consideration
    b4 you had 1 line, 1 hollow bolt, 2 seal rings
    now you have 1 adapter, 1 line, another adapter 1 flange 1 gasket 2 bolts and 2-3 addition sealing points that require debris laden paste to seal
    Nov 2005
    winnipeg, mb
    are you using flanges that have NPT fittings? I have some -4an inlet and -10an drain flanges for t3/t4 turbos that I'm trying to get rid of. Less adapters is always more reliable, less spots to leak!
  1. turbo sitting on my shelf leaking oil?
    By wontonjohnny in forum Forced Induction Talk
    Latest Threads: 10-05-2005, 03:49 PM
  2. WTB: Oil Feed Lines
    By CIVIC_MAN in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 04-21-2005, 01:03 PM
  3. WTB: Oil Feed Line For 1G DSM
    By Wookey in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 01-02-2005, 02:27 PM
  4. oil leaking out of filter
    By junboon in forum Bike Talk
    Latest Threads: 05-26-2004, 09:37 AM
  5. Civic's leaking oil somewhere or burning oil?
    By Seks in forum Mechanical
    Latest Threads: 11-07-2002, 10:39 PM
