For those of you who didn't know about my bike. My automatic cam chain tensioner failed the year before last. It screwed up everything in my engine. I purchased new valves a chain and a new tensioner. However when I got the new valves lapped and installed there were still compression problems. I decided to redo the whole top end.
Well I just put an order out for some new Suzuki parts
-4 Valve oil seals
-1 Cylinder Base Gasget
-2 Sets of Piston Rings
-4 Cam Bearing Dowels
I am going to rehone the cylinders, install the new rings and seals. Then it's down to measuring my valve clearance to the cam and installing new shims. Then the bike will need to be worn in again. I am also looking into a small shot of nitrous after this has been accomplished and the engine is worked in.
If you guys want to ad to this for information go ahead.
Later
