Help with Compustar Alarm/Starter - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Help with Compustar Alarm/Starter
    08 X5
    Default Help with Compustar Alarm/Starter
    I recently purchased a car which has a compustar alarm/starter and was wondering if their is any way to make the alarm more sensitive as well as change what each button does?
    Also i would like to know if its possible to have both doors unlock when i disarm the car as oposed to just the drivers door?
    Jul 2005
    I think if you want to open both doors just press the open door button twice, don't know about compustar though
    Originally posted by rage2
    #1: don't ever question me.
    The shock sensor has a dial you can turn to make it more sensitive.
    Buttons are hard programmed in. You can't change what any of them do. It should be easy to have both doors unlock - you probably just need to splice both unlock wires. Most cars usually only have one though.
    Drayton Valley AB
    what vehicle?
    Team Free-Air!
    08 X5
    Sorry guys i dont know much about cars
    what the hell is a shock sensor
    its an 01 Prelude SE
    08 X5
    Wish it was that easy.
    On those 5th gen Preludes there's only one unlock wire. Both doors should be unlocking. The door that doesn't unlock - does it work when you use the power lock switch that's actually on the door? Maybe the fuse is blown?
    The shock sensor is a small black box that's connected to the brain. There should be a sensitivity dial that you can turn on it. It says "shock sensor" right on it.
    08 X5
    Yes the door does unlock when i use the power lock switch..
    Any idea where this black box or brain is located?
    Is it under the hood?
    kryptonian meteorite
    check your steering column
    Nov 2005
    2015 Hyundai Veloster
    My 2005 Civic has priority unlock on the factory keyfob but when I had the Compustar hooked up it unlocks both at once and I was told there was no other way to do it with the Compustar.
    Originally posted by Go4Long
    Originally posted by blitz
    '07 Ranger FX4 Level II
    compustar has the alarm from the factory to have once 0.8 sec pulse for door unlock.. you can change this to have 2 pulses, or one long pulse though the programing mode... check your manual, or visit their website to get the instructions.. (should be the 2 pulse mode to unlock both doors)
    Feb 2004
    Medicine Hat AB
    You would have to wire the driver door lock actuator (2 relays) to the unlock wire of the Compustar, then the "2nd unlock wire" would hook up to your unlock wire in the car.
    Then you have to change the programming of the unit.
  1. FS. Compustar Alarm/Starter 2 remotes.
    By tool001 in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 04-14-2004, 10:25 AM
  2. FS: CompuStar Alarm/Starter
    By LancerGirl in forum Automotive Parts
    Latest Threads: 03-28-2004, 03:22 PM
  3. Good Affordable Alarm and Starter...(other than compustar)
    By Impreza in forum In Car Entertainment / Electronics
    Latest Threads: 11-25-2003, 03:29 AM
  4. Compustar Paging Alarm/Starter
    By cloppy in forum In Car Entertainment / Electronics
    Latest Threads: 10-22-2003, 08:00 PM
