Looking for a thinwall socket to buy or use to get my wheel nuts off. I think its a 21mm, or 19mm. For an SW20 MR2. If anyone has one, please let me know.
I know I can get them from stores, just seeing if anyone on the board has one. And I am not too sure on the size, and cant really measure it will the bolt still in.
Anyone know how 'thin' they actually are? I just checked and there is about 1mm between one corner of the bolt and the rim.
if you have a spare socket kicking around, you can grind the walls of the socket thinner. It might work for your purpose, but the socket owuldnt be much good for anything that will would put alot of force on it...
C.J.
1997 TSi AWD 2.3L 6 bolt (Carillo Rods, Wiseco pistons, Cometic headgasket, ACL bearings, removed BS, FP3's, Crower springs/retainers, ARP hardware), FIC 950's, Aeromotive AFPR with SS lines, Walbro 255HP, PTE SCM61, Tial wastegate, Greddy Type S BOV, short route FMIC, 3" turbo back, AEM EMS, 3 bar map conversion, BJs SMIM, 75mm TB, Innovate LC-1 Wideband, 18" Focals, Bridgestone Potenza RE040's, Tokiko suspension.
thanks, I might try that, Im going to be switching to tuner lugs after this, so I dont have to deal with this again.
I bought a thin-walled impact socket from Home Depot. It's branded Husky and is a 17 mm 6-point deep socket.
thanks!
