Bad fuel economy? - Beyond.ca - Car Forums
Results 1 to 20 of 21
Thread: Bad fuel economy?
    Default Bad fuel economy?
    If you think your 10k++ car is burning MORE fuel than it supoose to...maybe consider a new oxygen senser, thermostat, fuel filter etc...
    I'm getting those fixed.....and see how it goes may UP my performance too !
    oreo cookie
    a wrx.
    thermostat? if that went, u would have worse problems that would tip u off right away rather than bad fuel economy
    I wouldn't say the termostat is gone.... its old and not working as efficient as it should?
    just replaced mine in the shitbox, havent gone through a tank of gas yet so can't tell the mileage difference but it sure idles better now, especially on startup.
    oreo cookie
    a wrx.
    they either work or dont. if they dont work, u will overheat. simple as that!
    Aug 2002
    MDX
    chances are the coolant needs a flush, like jeff said, the thermo would fail or work. My 94 accord has shitty heat, has ever since I've owned it(5 years). Despite swapping thermo's and changing the coolant, it still sucks!
    I've had thermostats that failed in the open position. Car just doesn't get up to operating temp and there's little heat. Guess that's the lesser of two evils.
    Sep 2002
    CSpot
    11 sec weather van
    Actually, they'll typically stick open, causing overcooling.
    I have yet to personally see one stick closed.
    Aug 2002
    MDX
    my supra turbo's did regularly!!!
    ecstasy_civic's Avatar
    ecstasy_civic is offline MMA guru, but still rage2's bitch
    Aug 2002
    08 Si
    same problem as mine, just to scared of wrecking the small bolts on the therm. housing. it needs to be changed, maybe fri
    When you change it, buy the OEM part! I went through two aftermarket thermostats that didn't open at the right temperature before I bit the bullet and paid $45 for the OEM. Trust me, you don't want to swap thermostats more than once.
    Sep 2002
    CSpot
    11 sec weather van
    What year? strange......
    Im obviously immersed in ford and all ive seen is open ones.......
    Oh, and pop's talon tsi stuck open as well....
    Aug 2002
    08 Si
    i did lol it was expensive but hopefully worth it. the rubber gasket alone was 7 buck
    oreo cookie
    a wrx.
    see if theres a resistor somewhere behind the heater controls that u can adjust to crank the heat up...
    Good luck! Hope your thermostat is easier to get to than the one on my old 91 Si.
    oreo cookie
    a wrx.
    u bastard....u just love arguing with me dont u haha
    Sep 2002
    CSpot
    11 sec weather van
    You have proven your worthyness on the fun scale when it comes to arguing.......
    We are here for fun, right?
    335i
    It costs $45 bones for a OEM thermo??? Dammit...the ones at cdn tire are only 7 bucks hahah
    Anyways - I've noticed my heat doesn't get as hot as it used to, but it still is pretty warm. Since it's been stated that a thermo either works or doesn't, could it be the old coolant?
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    Could be the heater core. Now that's a bitch to change out.
    Oct 2002
    $45 for OEM is not as bad as close to $100 for some aftermarket ones some people are spending.
    http://www.polepositionproducts.com
  1. Improved Fuel Economy w/ Winter Gone?
    By Ekliptix in forum General Car/Bike Talk
    Latest Threads: 03-30-2003, 09:09 PM
  2. losing hp when using race fuel?
    By Ed the SOHC in forum Mechanical
    Latest Threads: 07-13-2002, 08:33 AM
  3. air/fuel lean!!!
    By LUDELVR in forum Mechanical
    Latest Threads: 06-19-2002, 12:32 AM
