65 Years Later, Jeep Continues to Offer More Legendary Capability
•More Off-road Capability - Increased ground clearance, larger wheels and tires, enhanced Dana front and rear solid axles, available next-generation Command-Trac and Rock-Trac transfer cases, new electric axle lockers, and electronic disconnecting front sway bar
•More On-road Refinement - All-new 100 percent stiffer frame in bending, 2-inch longer wheelbase, 3.5-inch wider track, lower spring rates, advanced shock tuning, increased jounce and rebound travel
•More Interior Space and Comfort - 4.6 inches more hip and 5.1 inches more shoulder room combined with additional 2 inches in couple, 1 inch in rear-seat leg room and 2 inches behind rear seat
•More Open-air Options - Dozens of different door, top and windshield combinations; new three-piece modular hardtop and innovative Sunrider soft top
•More Power and Torque - New 3.8-liter V-6 engine with 205 horsepower and 240 lb.-ft. of torque • More Safety - Electronic Stability Program (ESP), electronic roll mitigation, dual-stage air bags, seat-mounted side air bags and Occupant Classification System (OCS)
•More Convenience - Available power windows and door locks, full-screen navigation system, 368-watt Alpine stereo with MP3 capability, SIRIUS Satellite Radio
Jeep introduces the all-new 2007 Wrangler, the most capable off-road vehicle in the world - and more.
A direct descendent of the original Jeep - the 1941 Willys MB - the all-new 2007 Jeep Wrangler evolves from more than 65 years of legendary 4x4 leadership. Building on the successful, original Jeep formula with an all-new frame, exterior and interior design, engine, and safety and convenience features, Jeep Wrangler delivers more capability, interior space and comfort, refinement, power and open-air fun.
"The all-new 2007 Jeep Wrangler blazes a trail no other vehicle can follow," said Jeff Bell, Vice President - Jeep, Chrysler Group. "Just as it did when it first debuted in 1941, Jeep Wrangler sets a new benchmark in off-road capability.
"With more off-road capability, more versatility, more power, more on-road refinement, and more comfort and space, the all-new 2007 Jeep Wrangler continues its legacy as the Jeep brand icon. Simply put, it is the best Jeep Wrangler ever," added Bell.
Offered in three models - Wrangler X, Sahara and Rubicon - the all-new 2007 Jeep Wrangler is lean, rugged and simple, achieving best-in-class off-road capability while delivering a true open-air driving experience. With solid axles, removable doors, exposed hinges, a fold-down windshield and innovative removable and convertible tops, Jeep Wrangler retains the brand's coveted core values of freedom, adventure, mastery and authenticity.
With dozens of different top, door and windshield combinations, nine unique exterior colors and available 16-, 17-, or 18-inch wheels, the all-new 2007 Jeep Wrangler provides a customized appearance for a variety of customers.
More Legendary Off-road Capability
From ground clearance to articulation to traction, Jeep engineers focused on more than 50 functional objectives during development of the all-new 2007 Jeep Wrangler. The result is the ultimate "out-of-the-box" off-road vehicle with all the necessary features to "go anywhere and do anything."
"Reengineered and redesigned from the ground up, the all-new 2007 Jeep Wrangler is the most capable Wrangler in its 65-year history," said Mike Donoughe, Vice President - Body-on-frame Product Team. "With more ground clearance, better wheel articulation and advanced off-road hardware, Jeep Wrangler is designed to tackle the toughest off-road obstacles."
Improved ground clearance, combined with short front and rear overhangs, enables the all-new 2007 Jeep Wrangler to navigate the world's most challenging off-road trails, especially severe inclines. A boulder-friendly approach angle of 44.3 degrees and breakover angle of 25.4 degrees, along with a 40.4 degree departure angle, once again make the 2007 Jeep Wrangler the most formidable off-roader.
Providing unmatched wheel articulation and durability, Jeep Wrangler X and Sahara models feature an enhanced Dana 30 front axle and Dana 35 rear axle. For the all-new 2007 Jeep Wrangler Rubicon model - and optional with the trailer tow package on all models - heavy-duty front and rear axles are both Dana 44s, which feature numerous improvements. Providing significant underbody protection are three skid plates - protecting the fuel tank, transfer case and automatic transmission oil pan.
For the first time, Jeep Wrangler offers an electronic-disconnecting front stabilizer bar - Active Sway Bar System (ASBS) - delivering additional wheel travel for traversing the toughest trails. As a result, the all-new 2007 Jeep Wrangler boasts a 652 Ramp Travel Index (RTI - a measurement of a vehicle's suspension articulation) with the front stabilizer bar engaged and an 832 RTI with the front stabilizer bar disconnected - a 28 percent increase.
Jeep Wrangler X and Sahara models feature the second-generation Command-Trac NV241, part-time, two-speed transfer case, featuring a 2.72:1 low-range gear ratio. In addition, a Trac-Lok limited-slip rear differential provides extra torque and grip during low-traction situations, such as driving over sand, gravel, snow or ice.
The all-new 2007 Jeep Wrangler Rubicon model features an Off-Road Rock-Trac NV241 two-speed transfer case with a 4.0:1 low-range gear ratio, as well as electric front- and rear-axle lockers and 32-inch B.F. Goodrich Off-Road tires.
While improving its legendary 4x4 Jeep capability, the all-new 2007 Jeep Wrangler offers enhanced on-road comfort due to an all-new 100 percent stiffer frame in bending, 50 percent stiffer body, refined five-link coil suspension, improved shock tuning, 2-inch longer wheelbase and 3.5-inch wider track. In addition, new steering and suspension geometry provides precise ride and handling characteristics, and new sound-deadening techniques reduce cabin noise by more than 20 percent.
"The all-new 2007 Jeep Wrangler reaches new levels of on-road ride, handling and refinement - an achievement realized while also boosting its off-road capability," said Donoughe. "The new suspension enables the Wrangler to corner flatter with less lateral motion, provide better on-center steering feel, and even more effectively absorb on-road bumps and cracks."
Ride balance in the all-new 2007 Jeep Wrangler is more refined, achieving less body lean when cornering and braking. In addition, lower suspension spring rates provide a softer, more comfortable on-road ride. Standard on the all-new 2007 Jeep Wrangler is an Electronic Stability Program (ESP), which aids the driver in maintaining vehicle directional stability in severe driving maneuvers on any type of surface. ESP features three modes - "full on," "full off" and "partial on."
Standard on the 2007 Jeep Wrangler X model, low-pressure twin-tube shock absorbers are tuned to provide improved balance between jounce and rebound motions, achieving an extremely responsive suspension. Jeep Wrangler Sahara and Rubicon models feature standard high-pressure monotube shocks, utilizing Low Speed Tunable (LST) valve technology.
The all-new 2007 Jeep Wrangler's new recirculating-ball steering configuration features a robust cross-car steering linkage system, providing the stiffest possible steering linkage in a solid-axle vehicle, for a precise "rack-and-pinion" feel.
The 2007 Jeep Wrangler's all-new interior is designed to offer new features and functionality, increase passenger comfort and improve ergonomics. The spacious interior is athletic and durable, featuring a new instrument panel and center stack, and new high-back front bucket seats.
Interior volume provides significantly more passenger space, versatility and cargo storage. Featuring a front-seat area with 54.6 cu. ft. of space - an increase of 4.8 cu. ft. - the all-new 2007 Jeep Wrangler provides 5.1 inches more shoulder room and 4.6 inches more hip room.
New front seats are sculpted and conform to the body, and a driver's seat height adjuster is available for optimized seat position and comfort. Jeep Wrangler Sahara and Rubicon models feature cloth seats with YES Essentials fabric - an easy-care, soil-repellant and anti-microbial textile that protects seats from stains, odors and discoloration.
Rear seats comfortably accommodate two adults with 3.9 inches more shoulder room, 1.6 inches more hip room, 1 inch more leg room and a 2-inch greater couple than the 2007 Jeep Wrangler's predecessor. A fold-and-tumble feature allows rear seats to be conveniently stowed for additional storage capacity.
Two more inches of space behind the rear seat nearly doubles the cargo capacity of the all-new 2007 Jeep Wrangler. The extra space provides room for a new lockable underfloor storage area, which secures small items out of sight in the rear cargo area.
More Options for Open-air Fun
An all-new, three-piece modular hard top system features three panels - left- and right-front passenger panels and a rear panel - providing more options for open-air driving in the all-new 2007 Jeep Wrangler. Removing the left- and right-front passenger panels is simple and may be accomplished quickly by one person.
