Deck Installation problem Any suggestions? - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Deck Installation problem Any suggestions?
    Sep 2002
    '05 ACURA TL
    Default Deck Installation problem Any suggestions?
    I was installing my deck in my 93' p-finder and I know I hooked all the wires up properly but my deck will not turn on. The factory stereo has an amp which may have something to do with the problem but I highly doubt it. I tested the ignition wire and the constant power with a test light and everything has power my ground is also good I dont know any other problems that could cause this. Is my deck fried???? should I have it checked out????
    Check your in-line fuse (if you have one).
    Edmonton. Alberta
    FD
    also check the fuse on the back of the deck..... and if not you may have a bad ground.
    91 FD
    90 FC Turbo *sold*
    87 FC Turbo *sold*
    86 FC GXL *sold*
    Sep 2002
    '05 ACURA TL
    Default checked
    checked both any other suggestions?
    V167
    you're using the metra harness? make sure you did not switch the remote amp turn on and power antenna wires (both are usually blue off the headunit and can be easily mistaken)
    2018 Ford F150 SCREW
    Take it out and bring it to cash converters. They will just hook up the remote and the power and the ground. If it doesn't work then i would have it looked at. If it does then try taking everything out and starting again.
    Just ideas.
    The depths of despair!
    Anything topless.
    just find a power source and stick both the yellow and red wire to it. Just make sure that there is a constant 12V power supply going to both wires. It should turn on, if not, then the deck itself maybe whooped.
    WTF!! I am a moderator!!
    Jul 2002
    Cowtown
    08 VQ35HR
    some factory external amps require a low signal/voltage input... If it's a factory deck+factory amp combo, then the factory deck's most likely outputing a low power to the amp to be amplified. When you hook up an aftermarket deck (high power) to your factory amp, then your amp is going to clip off because it's gonna try to amplify an already amplified signal since they'd create some nasty distortion. I'd remove the factory amp completely unless it's a high end one... or else you won't be utilizing the full potential of your new aftermarket deck PA.
    Sep 2002
    '05 ACURA TL
    Default Thanks alot !!!!
    I'll try this thanks alot I appreciate it!!!!
  1. Any Suggestions for a car with limited budget?
    By tommy1223 in forum General Car/Bike Talk
    Latest Threads: 06-22-2004, 11:08 AM
  2. Any suggestions for tires on Lexus IS?
    By sleek in forum Performance Modifications
    Latest Threads: 04-18-2003, 12:08 AM
  3. Deck Problem?!?
    By BigBearWest in forum In Car Entertainment / Electronics
    Latest Threads: 01-19-2003, 08:51 PM
  4. ANY suggestions on.....
    By surferbaby13 in forum General
    Latest Threads: 12-31-2002, 02:11 PM
  5. Poor Ford just doesnt get any breaks..gt40 problem
    By Redlyne_mr2 in forum General Car/Bike Talk
    Latest Threads: 11-18-2002, 07:41 AM
