The OFFICIAL Ebay Turbo "Kit" Thread - Beyond.ca - Car Forums
Results 1 to 20 of 35
Thread: The OFFICIAL Ebay Turbo "Kit" Thread
    6.7 CUMMINS, E50 AMG
    Default The OFFICIAL Ebay Turbo "Kit" Thread
    The OFFICIAL Ebay Turbo Kits Thread yay!
    using this auction as an example
    I will try and upload this page to a webspace for future refrence.
    Let me start by saying I know a lot of people already know a lot of what I will say in this thread. Some will agree and some will disagree. This is more for the people who don’t have any experience and who may think this is a great deal.
    It seems like a lot of prospective turboers express an interest in these kits since it seems they will save them thousands of dollars. So let’s take a look.
    I picked the most complete kit I could find for my example. It is officially named the “D16 SUPER SINGLE SLAM SETUP” by the seller. It was also one of the most expensive “kits” as it came in at a whopping $925 usd buy it now + shipping and brokerage charges. Usually these guys will only ship these whole kits via UPS or Fedex ground. So get ready to bend over.
    These kits are generally all the same. They usually include an obscure named turbo (or no name at all!), a “Tial style” wastegate, a “Tial style” or “TurboXS style” blow off valve, a polished stainless manifold, polished stainless downpipe and charge pipes, an intercooler, an assortment of brass fittings, clamps, couplers, hoses…etc… usually described as below:
    Garrett T3/T4 TO4E Turbocharger
    .50 STAGE iii WHEEL
    GARRETT HYBRID
    GARRETT INTERNALS
    (1) SUPER RACE TURBO MANIFOLD
    STAINLESS STEEL
    (1) STAINLESS 4 BOLT DOWNPIPE
    ( Hand made tig )
    (1) Full set of TIG Welded Complete (5) piece 2.5" charge piping.
    (1) WASTEGATE DUMPTUBE
    (1) SUPER 38MM WASTEGATE
    (1) SUPER RFL BOV
    ( 1 ) SUPER 680mm X 460mm X 180mm INTERCOOLER
    The seller further goes on to describe the turbo manifold:
    HAND MADE STAINLESS STEEL RUNNERS 45MM , POLISHED
    3/8TH THICK FLANGE
    2.2MM THICK PIPE - WILL NEVER CRACK!
    SUPPORT WELDS ON EACH PRIMARY TUBE
    POLISHED STAINLESS STEEL
    PORTED FOR HUGE HP GAINS!
    So besides the obvious cheesiness and mistakes in his auction description we have a pretty basic understanding of what were buying.
    -So let’s start off with the turbo manifold.
    Normally these come with 3/8” stainless steel flanges. They use stainless because it polishes up nice. The preferred material for flanges is cold rolled steel. Mild steel is MUCH less susceptible to warping due to heat. It is also a lot easier to machine, especially after welding and or use.
    To add a 3/8” flange will warp over time and use. If the flange does warp and you must get it machined you may not have much left after enough material has been removed to make the surface true!
    Another thing relating to thickness; these manifolds will crack (will elaborate next). If the crack is fixed properly i.e. Tig welded, it will change the length (sort of. maybe more like stress) of that part of the tube that is being repaired. If this happens you’re almost sure to warp the head flange (depending on where the repair is done on the tubes and how bad the crack was)
    So on to the tubing. We all know these are made cheaply overseas. The mill spec on the metal tubing they use is normally very poor. This means that the quality of the actual metal can very greatly between manifold to manifold.
    Also this seller is claiming that his manifold is 2.2mm thick. Most of these manifolds were upgraded a couple years ago from standard 0.065 wall or 16 gauge tubing to 14 gauge due to mass failure. They were all cracking bad. So they upgraded one gauge thickness. This helps but is still pretty thin for a turbo manifold. Combined with shitty mill spec you get manifolds that do crack after a while.
    I know someone who has been using one of these manifolds for about 2 years. He welded braces on it as soon as he got it. The car has probably only had about 10k put on it and the manifold is cracking like crazy. Most people I talk to who have/are running one of these do have problems after a while. Normally it’s not the welds that crack (although many have) it’s a crack in one of the un welded sections of tube.
    -So next is the actually Turbocharger itself.
    These things really are junk. I have had the pleasure of seeing a couple of these in person. The quality of the castings is terrible; the machining of the housing and cartridge is downright horrible. Bolt holes milled/tapped crooked. Bolt holes too close to the edge of the casting. Crooked mating surfaces. Sloppy edges….etc….
    One can only assume the quality and tolerances held by the oil rings, thrust bearings ….etc… would not meet very high standards. These things fall apart, leak, and don’t spool properly….etc...
    -The bov and wastegates are copies of real products. I have seen these bov’s work and not work. Also this style bov doesn’t work well in cold weather. Just the design.
    For me, a wastegate is the last thing I would be cheaping out on. If it fails kiss your engine bye bye. I have seen first hand one of these eBay wastegates fail. One of the little screws that hold a piece down to the diaphragm came loose. If you take your new wastegate apart and make sure everything is ok and tight you should probably be ok.
    Like I said, I would never run one on my own car.
    -As for charge pipes I cannot verify if these do in fact fit ok. I have never seen them, installed them or know anybody who has.
    -The clamps and silicone connectors in this kit seem nice. T bolt style and real silicone. Looks good.
    -I would not bank on using any of the oil routing hardware. It’s all brass and looks cheap, also incomplete. I would not ever use brass fittings on any of my own cars.
    Be prepared to spend at least $150 for your oil feed and return at mopac. I always use Aeroquip and earls fittings/lines. That way you don’t every have to worry about it!
    -Ebay intercoolers generally seem to be ok. This one is almost exactly the same as a precision core. They probably come from the same place lol. The other ones I have seen, tube and fin, are pretty heavy duty construction, work well. I would rock an ebay ic if i was on a budget.
    I'll edit / add as i think of stuff
    Civic dx
    Consensus, JUNK!
    I'll let people make their own decision on that. I just wanted to share my actual experience with these parts.
    Chevy Colorado ZR2
    Corey made me spend mad moola on the oil return lines (inset), but in the end it's so worth it. He threatened me that if I use cheap parts he won't touch my car
    I think a lot of people just want to go fast for cheap. I would not touch these kits with a ten foot scientific pole.
    Jul 2002
    calgary, alberta, canada
    Mall Crawler
    when it comes to turbo'ing your car don't go ghetto, buy the right parts the first time and don't deal with headaches. trust me, i've tried ghetto and i've tried authentic parts, the difference is night and day
    Probably the best piece of advice for anyone looking to turbo (or modding in general).
    957,958,NC1,NC3,E60,ITR
    Default Re: The OFFICIAL Ebay Turbo "Kit" Thread
    Originally posted by legendboy
    in this pic, the piping from the cold side of the intercooler up to the TB doesn't look like it'll fit without some serious modification.
    Aug 2003
    95 AC INTEG 90 crx si
    sweet man. Id been wondering about those turbo kits and why they so cheap.
    dang was i really that mean! haha
    hows your dawg running anyways?
    Jul 2002
    hehe I'll ask him he works one floor below me. what a small world
    Jun 2003
    CALGARY
    92SiR, 05B5G, 89KA24
    welding braces to the manifold and block will help support the weight evenly?
    yes it will help. problem is the tubing they use will crack anyways just from the heat alone
    '08 Mitsubishi Lancer, '97 GMC Jimmy
    ....this is why instead of being a cheap ass, when i do serious mods like replacing the Turbo and Internals, i know to properly do it its going to cost over $10 g's. so Im not gonna cheap out now and do it for a few thousand. Good Advice.
    Civic dx
    yea ofcourse going fast is going to be expensive. Thats fine though cuz if you could get 50hp for $400 everyone would have that power and you still wouldnt be fast.
    Jul 2002
    Mall Crawler
    going RELIABLY fast is expensive
    Jun 2003
    CALGARY
    turbo mani
    turbo
    downpipe
    charge pipes
    wastegate
    bov
    tuning
    when cheaply done about 1000 - 1500 on a honda platform
    i dont see how running low boost (5-8psi) can affect reliability
    btw: 50 extra whp is alot (of difference) on a fwd car
    Chevy Colorado ZR2
    It's running fine though I'm condemned to use anything lower than 94 octane because it detonates. The reason being is that I tightened the wastegate rod and I'm actually shooting 6.5-7psi now instead of the 5 - 6 psi before.
    When I ran my car on dyno day the rod was loose so I wasn't getting the full potential of the wastegate.
    Looking forward to the next dyno day. A Blitz Dual-SBC boost controller will be there by then.
    Aug 2005
    RD AB
    2006 cadillac, 2008 civic, 98 volvo v70
    Thanks for posting this people need to realise you get what ya pay for
    Feb 2005
    Saskatchewan
    i dont mean to bash anyone and especially you legend boy. your manifolds looks awsome and definatley a quality peice of work. obviously much better than the ebay kits. anyways i found this on honda-tech. thought some of you might be interested. im not saying ebay kits are wicked quality, they are just not as bad as people make them out to be.
    sorry, new link
    http://www.spdweb.net/index.php?opti...d=76&Itemid=64
    93 Civic Hatch
    12.0 @ 116mph (10psi)
    a.k.a "50 footer"
  1. Official "what does your name mean" thread
    By ReMiXed lude in forum General
    Latest Threads: 03-29-2020, 09:20 PM
  2. "not the official" Stanley Cup Game 1 thread
    By Strider in forum Sports, Health & Fitness
    Latest Threads: 05-27-2004, 11:29 AM
  3. Replies: 14
    Latest Threads: 04-09-2003, 12:28 PM
  4. The "Official" who is going to win the cup thread!
    By Speed_RaSiR in forum Sports, Health & Fitness
    Latest Threads: 04-08-2003, 10:41 PM
