Hi im selling an E46 M3 CSL diffuser, the lip is made out of CF. And the rest are made out of Fiber glass i believe. 2/6 Clips are busted (easy fix at a body shop) problem is the carbon fiber has a slight blemish, the clear coat has a slight crack in it (the CF is NOT cracked) just clear coat. about 1cm x 1cm. im sure u can paint it over or ask the body shop what they can do about it.
My price is $200 CAN. CHEAP!!!
thanks
-Darren
I recently installed one on an E46 M3, Fitment is next to none! i can install it for you if you get it painted. Tip: You can probably paint that CF Blemish and just leave the CF lip, OR you dont have to fix it and u can leave it because if you look at the picture the diffuser sits horizontal so in order to see the blemish, you'de have to get on your knee's and stomach to see it...
