hooking a cap to CPU - Beyond.ca - Car Forums
Results 1 to 16 of 16
Thread: hooking a cap to CPU
    High River
    2004 Mini Cooper
    Default hooking a cap to CPU
    Looking to install a Computer system in the car...
    What I want to know can I hook up a cap to the computer to supply more power to the inverter?
    yeah I know most of you are going to say WTF you want a computer in a car for??? Well its just a project nothing more nothing less..
    Thanks for the input people!
    Victoria, BC
    A cap won't do anything for that application.
    High River
    2004 Mini Cooper
    ALright so how would I provide more power to the inverter?
    Any other ways then gettin a new alternator?
    Victoria, BC
    There is no quick solution to providing more power to the inverter other than than basics: better alternator and better battery.
    caps only provide power for a short time(seconds) when there is a need for high amperage
    Jan 2003
    Edmonton, AB
    2010 Genesis Coupe
    you need a decent alternator, about 65 amps i belive, and one of those inverters they sell at canadian tire, get about 250-300 watts.
    computer in a car is a great idea, you can play games like all the PS2 installs, and dvds, and music, and have a navigation system, among other things.
    been lookin at that project for a while now
    Victoria, BC
    65amps?
    haha
    most stock car alternators are around 80 amps
    ~60amps are used by the car in normal operation with every accessory running, and there is a 20amp provision generally for future accessories(stereo, etc)
    20amps aint much to work with
    High River
    2004 Mini Cooper
    so only option is to get a better alternator?
    I drive a 92 Geo Storm and this is the car I wuld like to use for the prject, Can any one reccomend a good place to get a alternator and have it installed.
    thanks for the input
    Victoria, BC
    have you started? is power posing a problem or are you anticipating it to be a problem
    Cochrane
    http://www.apcc.com
    try one of these..
    High River
    2004 Mini Cooper
    I had it installed on a test run. Started u8p fine for about 10 min then inverter would shut down because of low power from the battery.
    Also the alernator was too hot to touch.
    so I was guessing that the alternaror was workin too hard to power the battery...
    Computer Specs..
    Durron 800 MHZ
    128 MB SDRAM
    4 MEG VID card
    keypad
    PsOne LCD
    sound is hook into the deck.
    '07 Ranger FX4 Level II
    Hook up a second alternator, and mabey two batterys.. but thats a 3cyl right?
    Originally posted by rage2
    Cochrane
    Use a battery backup from www.apcc.com
    or buy a 450W inverter $150 from canadian tire i believe
    High River
    2004 Mini Cooper
    already have a 300 watt inverter and it shuts down due to low battery what is a 450 watt inverter going to do for me?
    Jan 2003
    MoO
    get somekinda amp forit.... just a small one
    Jul 2002
    Cowtown
    08 VQ35HR
    You don't need a cap if you want to install a computer in your car... it's freaking only 300-400W of power and it's not even using all of it, so it's probably realistically around 200W... Most aftermarket decks are about 200W and you don't see people hooking up moster caps to stabilize their system!!! Plus computer's run on pretty much constant current unlike higher end stereo ampifiers.
    Jul 2002
    Cowtown
    08 VQ35HR
    It depends on your computer case power supply. If it's rated at 300W, then a freakin 300W inverter ain't gonna do you any good... In electronics, always account for 50-100% more juice than you really need.
  1. WTB: PII or PIII Motherboard and CPU
    By spyderman in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-05-2003, 01:15 AM
  2. Wtb: Cpu
    By Speed_RaSiR in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 12-16-2002, 11:59 AM
  3. p3 cpu, motherboard & ram
    By SuperG3 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 12-11-2002, 09:21 AM
  4. FS: Celeron CPU
    By egmike in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-25-2002, 09:29 AM
  5. FS: Rockford 0.50 Cap and Cap Kit
    By Audi Kid in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-20-2002, 02:32 PM
