Heys all, anyone have more info on the new road going up in the NW of the city.
Ie...when completed and that. and if there is an interchange at
Shag ?
Shag ?
http://www.trans.gov.ab.ca/Content/d...on/cphpmap.htm
Although map isn't clear but I doubt shag will connect to the ring road because that will require plowing thru the new neighborhood of Sherwood and I havn't seen any plans of any major road thru that area past Country Hills.
The 2 closest exit would be Sacree and Beddington Trail.
its like the ring road that goes around tokyo lol. frist thing i thought of when i saw that picture was tokyo extreme racer
Alright, race track with huge dump trucks and 18 wheelers..
what will be the speed limit on that new road ?
They're already working on the interchange at Shaganappi and Stoney Trail. Right by the new Home Depot and Costco! It's right in between Hidden Valley and Sherwood.Originally posted by Xtrema
Really? they are working on the interchange..in that map it doesn't show an interchange tho ?
Fall 2007 is the projected completion date ... pipedream?
Looks like they are going right in between Sherwood and Kincora. This should be awesome, 2mins from my driveway to the freeway.Originally posted by Xtrema
http://www.trans.gov.ab.ca/Content/d.../stshag-m1.pdf
"Having a war about religion is like having a fight over who's got the best invisible friend" - Yasser Arafat
Most of the Deerfoot interchanges took about a year to build each. Seems reasonable.Originally posted by red01
There is more open space then you think there. As was already mentioned they are already working on the road, and have already ripped across the far end of Shaganappi trail (past hidden valley) in 2 places.Originally posted by Xtrema
[url] that will require plowing thru the new neighborhood of Sherwood and I havn't seen any plans of any major road thru that area past Country Hills.
The Shaganappi extension into sherwood was listed as temporary over a year ago...looks like things have changed.
Ohh! I was wondering why there was a cross section cutoff from the access road to Sherwood going from behind hidden valley to behind the hamptons. Thought they were just laying down pipes. This should be nice. The 2007 date could be a possiblity for this section at least cuz the workers are going pretty fast.Originally posted by CLiVE
so sherwood...you would beable to access that community from Sarcee and Shag?
I sure hope so. I hope they don't close the access to Sherwood from Shag because it's really convienient. It will take much longer to get to other parts of the city using Sarcee vs Shag.Originally posted by Dren
I cant wait until stoney trail + 16th interesction is changed
We had a vote in oakridge/pumphill and that area in b/w that for some reason I can't remember the name of, regarding the ring road and 90th ave. Not sure what the results were but we voted no for the connection.
Reason being the 90th ave to 14th street is a nightmare. However I don't know what number of drivers would then bypass 14th all together instead opting to take the ring road all the way up to glenmore, however from the map it looks like the connection would occur closer to sarcee than Crowchild, so this ring road could actually cause headaches for our community unless 14 st is widened along with 90th ave.
anyone have an idea. if its going to be like a highway?
or like stony trail and the way it is with a speed limit of 80..
wish it would be 110...
