Where can I get 9006/9005 -> H4/H1 Conversion Harness? Any place in Calgary sells these? I need them ASAP!!!
H4 uses a normal headlight pigtail you can get from autovalue...H1 bulb just use an un-insulated terminal
HKS T04Z Bridgeport FD3S
Go to Princess Auto. They have all the parts you need to make your own.
Do I just solder the current harness with the ones off the headlight? BTW this is for a set of Accord Stanley blackhousings. Thanks for any help.
are the stanley ones just aftermarket or like jdm?
the 4th gen prelude has the same setup for USDM to JDM headlights. the 9005/9006 to h1/h4. the issue comes that the jdm headlights use the highbeam filament in the h4 for the "lowbeams", according to the stock wiring diagram and plugs.
there is an elaborate wiring diagram you can find on the net that will utilize the high/low on the h4's and use the h1's as "aux" lights. the easiest wiring is to simply solder right onto the lines. i didnt bother cutting my 9005/9006 plugs off, and just tapped the h1/h4 plugs right onto the 2 wire line. thus the h1's became my DRL's and highbeams, and the h4 highbeam filament became my lowbeams.
Its JDM Stanleys. Would you have the wiring diagram to use the H4 as low/high beam? There is only a positive and a negative ground for the H4 plug on the back. How effective is the high beam with the H1 bulb? Probably won't matter anyways cause I don't use it that much. These are the pics for my headlights:
