im havin troubles getting my voicemail on my phone (V551)
i can get it if i use a diffrent phone, just curious what # do u put in to get?
you should be able to dial your number to yourself on that phone and have it go to voicemail...
ya when i type my # it just says its busy
you on rogers? if so, try this number:
561-3172
what does that # do? just so i know before i call it
same thing as if you call your voicemail... you need to put in your number (including area code) and then your password and then acesses your voicemail from there.Originally posted by pyro
awesome thanx for the help![]()
It's something with your routing. Carriers have your voicemail set up conditionally. There's CFNA which is Call Forward No Answer and CFB which is Call Forward Busy. So if you're calling it from another phone, it's ringing, you're not answering it and it's going to voicemail, that means your CFNA is set up correctly. But if you're calling it from your own cell phone and you're getting a busy signal instead of your voicemail, that means your CFB is set up wrong because it should be routing to voicemail instead of giving you that busy signal. Just call your provider man.
Originally posted by Go4Long
you do realize this is the internet right? lolOriginally posted by rob the knob
then you will be happy if you fine place in liveOriginally posted by blitz
