Behind the Wheel - April 12, 2006: Steering Wheel Hand Placement - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Behind the Wheel - April 12, 2006: Steering Wheel Hand Placement
    Dec 2003
    Nanoose Bay, B.C.
    '05 Toyota Tacoma
    Default Behind the Wheel - April 12, 2006
    Have you ever done an article on hand placement on the steering wheel? This is essential to avoid a collision or to regain control of your vehicle in an emergency situation of any kind.
    Who would have thought that how to hold a steering wheel would change, or that it even mattered. This reader is right to point out that a refresher is due for drivers from the age before airbags. The 10 and 2 crowd are now out of date!
    The best theory today is for the left hand to be between 7 and 9, and the right hand to be between 3 and 5. This keeps your hands and arms out of the way if the airbag deploys and you don't end up having a fist fight with yourself in the event of a collision. Please note that these instructions call for both hands to be on the wheel.
    Hand over hand has died a quiet death except in low speed parking lot style maneuvers. The method to use now is called either push-pull or shuffle steering depending on who you talk to. The steering wheel is pushed with one hand and then pulled with the other, effectively shuffling the wheel between hands. Neither hand ever passes the 12 or 6 position and the wheel is not allowed to slide through both hands at once as it centers after a turn.
    A check with an ICBC driver examiner reveals that should you palm the wheel, use only one hand to steer or grasp the steering wheel from inside the rim it will be marked as an error on a driving test.
    This method may take some getting used to, but it promises two benefits: you will be less likely to overcorrect in an emergency and you will suffer less fatigue in your arms and back, arriving at your destination in a safer more comfortable manner.
    Reference Links
    Have you ever met anyone who would admit to being less than a better than average driver?
    Search Behind the Wheel at http://www.drivesmartbc.ca
    Dec 2005
    2009 Forester
    I've read some articles where they claim that wrapping your thumb around the steering wheel is "bad" because if you get a blow out or something suddenly jolts the steering wheel you can sprain/fracture your thumb.
    Can you comment on this?
    Tim
    Dec 2004
    Turbomedic can probably enlighten on this one. I have heard from a firefighter friend that he has seen some hand injuries from the steering wheel airbag, but minor facial injuries are still more common.
    Originally posted by 01RedDX
    Eye for an eye should apply to both, like if you raped a cat, you would get raped by a bigger cat. Counselling doesn't work on animal rapists you clown.
    V167
    There was a pretty gross hand injury posted by somebody on Vwvortex caused by their air bag. Picture your thumb basically being ripped/seperated from the rest of your hand with a big gaping hole in between your thumb and pointer. (ie: spread your fingers as far as they can go....and picture your thumb being stretched wayyyy further).
    Jun 2004
    When you're airbag goes off it's an explosion contained within the fabric. That's why you need to wear your seatbelt to keep your face away from it.
    "It takes a big man to admit when he is wrong....I'm not a big man" Chevy Chase, Fletch Lives.
    Dec 2003
    Nanoose Bay, B.C.
    '05 Toyota Tacoma
    I just did a Google search on the topic and didn't come up with much that was useful on this topic other than drivers whose airbags had deployed suffered minor thumb injury.
    Toronto, ON
    S54 M Coupe
    In severe impacts, it can happen. If you watch open-wheel racing, you'll notice the last thing they do before they hit the wall (especially in high-speed impacts on ovals) is let go of the wheel.
  1. Behind the Wheel - April 5, 2006
    By skidmark in forum Society / Law / Current Events / Politics
    Latest Threads: 04-06-2006, 02:41 AM
  2. Behind the Wheel - April 20, 2005
    Latest Threads: 04-20-2005, 01:04 PM
  3. Behind the Wheel - April 13, 2005
    Latest Threads: 04-18-2005, 01:06 AM
  4. Behind the Wheel - April 6, 2005
    Latest Threads: 04-07-2005, 09:01 PM
