e-brake override - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: e-brake override
    Default e-brake override
    you've probably been asked this before but,
    i have been told to ground the e-brake, put power to the e-brake, ground the foot pedal wire and everything. Is there anyway to overrided the "safety feature" so it can go all the time.
    (on an alpine reciever)
    Aug 2002
    MDX
    why?
    so other people in the car can play PS2 and watch tv
    Ground the E-brake IN signal to the TV instead of hooking up the e-brake signal.
    been there, done that
    it still doesn't work
    alpine is messed up you have to press the footbreak, pull the e-brake, turn the e-brake off, pull it on again, and then release the foot break.
    it's messed up
    it's messed up
    Easy.. Simualte the pressing of the Footbreak 12V, Ground 12v, ground Again..
    Use some Monetary switches and it should work.. you'll need to do a sequence, but if you really want it to work.. By pressing, the footbreak. it wants to see 12V for the Brake Wire, then pulling the Ebrake, it wants to see 12V for the e-brake wire, to get e-brake off it wants to see ground or loss of 12V, pulling it up again it wants to see 12V, and releasing the footbreak it wants to see "ground"..
    hope that makes sense.. assuming your info is correct..
    yeah alpine makes it pretty damn complicated
    i just went to radioshack to pick up some switches.
    thanks for your help.
  1. good brake ducts...better brake ducts???
    By REFLUX in forum Performance Modifications
    Latest Threads: 04-03-2003, 07:23 PM
  2. FS:AEM Big Brake Rotors For 97-up Prelude
    By WBB6 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-18-2002, 02:55 AM
  3. help bypass parking brake lead on clarion
    By boxster in forum In Car Entertainment / Electronics
    Latest Threads: 09-15-2002, 11:58 PM
  4. Brake pads?
    By B18C in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-07-2002, 02:16 AM
  5. Brake rotors... high and low quality??
    By homie in forum General Car/Bike Talk
    Latest Threads: 07-13-2002, 03:54 PM
