rim sizing - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: rim sizing
    Mar 2005
    Default rim sizing
    no one make fun and no funny business
    i am really illiterate when it comes to cars
    especially mine!!
    i need rims and ive already made the misatke once and bought rims that dont fit.
    so i need to know what will fit my car and what do i neeed to know....
    so far i have figured out i have 5 x 100 and 17 x 7 will fit but what size of tires is the maximum and what the hell is this offset...
    Mar 2005
    one mroe thing if i have tires that are 225 but the suggested width is 215 any problems?? or ways to go around it
    Ummmmmmm... What is the exact vehicle?
    Mar 2005
    haha 97 grand am se
    Jun 2005
    Whitehorse, YT
    2000 Civic SiR, 1984 Shadow 750
    If you want to go up to a 17x7", the recommended size is 215/45-17 assuming that your car came with 195/70-14 or 195/65-15 as stock. Your offset would be 40.
    Visit CMS's website at www.shopcms.com and use their program to verify these numbers if you wish.
    Hope this helps.
    Generally speaking on a car such as this, with a 17x7 you can run anywhere from an ET35 to and ET42 without issue (assuming the car is in good condition with no suspension issues or mods). ET38 to 40 is optimum fit...
    Offset is simply the measurement which indicates how far out or how far in the wheel will position under the fender... The higher the number, the more the wheel will tuck into the car (towards the suspension side)... The lower the offset number, the more the wheel will push out towards the fender.
    If the offset is too low or too high, you will experience rubbing problems either against the suspension, brakes, or fender (inner or outer)...
    215/45R17 would definitely be the size to use (as per hondafetish's reccomendation) in 17 inch if either of those was your original tire size...
    Mar 2005
    so 42 is okay then??
    and if the rim i have has 225 on them could i slip on 215 with no issues and vice versa from 215 onto the rims that have 225
    Dec 2005
    Alberta
    A31 Cefiro
    Here is a pic that describes offset a little better.
    It basically show where the wheel connects to the cars hub in relation to the wheels center.
    Mar 2005
    hahah more confused then ever but hey its all good
    i got rims got them istalled and there fine haha stillhave no clue but if it works it works
  1. Rim Sizing
    By snowboard in forum Nissan 240sx / Silvia Owners
    Latest Threads: 08-15-2005, 12:36 PM
  2. tire sizing
    By darth wolf in forum General Car/Bike Talk
    Latest Threads: 12-02-2004, 11:57 AM
  3. Box/Carriage bolt sizing?
    By Workhorse in forum General Car/Bike Talk
    Latest Threads: 10-24-2003, 11:23 AM
  4. Need help with sig (pic sizing)
    By Canadian 2.5RS in forum General
    Latest Threads: 02-19-2003, 12:41 PM
  5. Re-sizing image....
    By CRXguy in forum General
    Latest Threads: 10-09-2002, 12:32 AM
