Ford Shelby GT500 officially rated at 500hp/480lb-ft tq - Beyond.ca - Car Forums
Results 1 to 11 of 11
Thread: Ford Shelby GT500 officially rated at 500hp/480lb-ft tq
    Not Aspen
    Two from Freemont
    Default Ford Shelby GT500 officially rated at 500hp/480lb-ft tq
    2007 FORD SHELBY GT500 OFFICIALLY RATED AT 500 HORSEPOWER
    # Ford Shelby GT500 officially rated at 500 horsepower, 25 horsepower higher than preliminary estimates
    # The Shelby GT500 will go on sale this summer with more horsepower than any previous factory-built Mustang
    DEARBORN, Mich., May 2 - The most powerful factory-built Mustang ever just got even more potent. Final certification testing of the Shelby GT500’s 5.4-liter supercharged V-8 shows it will produce 500 horsepower and 480 lb.-ft. of torque – 25 more horsepower than preliminary estimates.
    “With 500 hp and the Shelby name, this car is an instant legend," said Hau Thai-Tang, director, Advanced Product Creation & SVT programs. "This is the most powerful, most capable Mustang ever."
    The Ford Shelby GT500's supercharged 5.4-liter, 32-valve V-8 is a result of Ford's experience in developing the modular V-8 and V-10 engine series. The engine is force-fed air via a "Roots-type" supercharger providing 9 pounds per square inch of boost. It borrows the four-valve cylinder heads, piston rings and bearings, from the Ford GT engine.
    The 500 hp rating was obtained using the Society of Automotive Engineer's latest standard and was witnessed by an objective third party. The Shelby GT500's 5.4-liter supercharged V-8 will be built at Ford's Romeo Engine Plant in Romeo, Mich. Pricing will be announced closer to launch.
    The right to purchase the first 2007 Ford Shelby GT500 was auctioned for $600,000, with the proceeds benefiting the Carroll Shelby Children's Foundation. The 2007 Ford Shelby GT500 goes on sale this summer.
    Technical Specifications
    Type: V-8
    Manufacturing location: Romeo, Michigan
    Configuration: Iron Block and Aluminum Heads
    Intake manifold: Cast-aluminum with Roots-type supercharger and air-to-water intercooler
    Exhaust manifold: Cast iron
    Crankshaft: Forged steel
    Throttle Body: Dual 60 mm, electronic
    Valvetrain: DOHC, 4 valves per cylinder
    Valve diameter: Intake: 37.0 mm; Exhaust: 32.0 mm
    Pistons: Forged aluminum
    Connecting Rods: Cracked forged steel I-beams
    Ignition: Coil-on-plug
    Bore x stroke: 3.552 x 4.165 in. / 90.2 x 105.8 mm
    Displacement: 330 cu. in. / 5,409 cc
    Horsepower: 500 hp @ 6,000 rpm (SAE Certified)
    Torque: 480 lb.-ft. @ 4,500 rpm (SAE Certified)
    Compression ratio: 8.4:1
    Redline: 6,250 rpm
    Idle Speed in Neutral: 750 rpm
    Engine control system: Spanish Oak PCM
    Required fuel: Premium
    Fuel Injection: Electronic returnless sequential
    Oil capacity / type: 6.5 quarts / Motorcraft 5W-50 Full Synthetic Motor Oil
    Coolant capacity: 21 quarts
    Peak Boost: 9 psi
    May 1, 2006
    Oct 2002
    Torque Factory
    Apex Predator
    Oh sweet jebus! 500HP/480lb.-ft.
    "She takes premium dude! PREMIUM!!! DUDE!!!!"
    It's too bad its so hefty at 4000lbs. Not that it matters too much with 500hp. It'd make a damn fine cruiser .
    Not Aspen
    Two from Freemont
    yeah, aparently the engine block, heads and blower together weight 700 lbs.
    Feb 2004
    Bavaria
    Model 3 Performance
    A 500HP Mustang with factory warranty. Even I'd roll in that.
    Oct 2002
    Torque Factory
    Apex Predator
    I wonder if its underrated like the 03/04 Cobra and Ford GT.
    Elbonia
    Jeep of Theseus
    Damn, and I thought they weren't going to stray near the GT numbers - you could probably hit 550HP with a smaller blower pulley!
    Carolina
    GMC Acadia
    Damn, I was gonna post this yesterday but forgot
    Pretty sick numbers, now if only they could do something about the weight... aluminum block maybe
    EDIT it could also use a redline closer to 8000
    Originally posted by VIZSLA
    Seems that running qualifying in three heats worked so well we're now running the race in three parts too.
    1, On the track
    2, In the steward's box
    3, In Paris
    Feb 2004
    Niagara Falls, Ont.
    2002 Toyota Corolla
    that should be one hell of a car, won't be underrated tho, it's been measured and certified with that new SAE certification. that is unless they alter the spec of it post certification
    Oct 2002
    22 ZR2, 06 YZ250, 77 KZ1000 supercharged
    Sweet, how much tho?
    Carolina
    GMC Acadia
    40-45k US, I think. Probably on the higher end of that...
    1, On the track
    3, In Paris
  1. Project Thread: 1968 Shelby GT500
    By BerserkerCatSplat in forum Cars, Bikes, Machines
    Latest Threads: 09-05-2006, 10:31 PM
  2. Ford Shelby GT500 Convertible
    By Gripenfelter in forum Automotive News
    Latest Threads: 01-09-2006, 06:44 PM
  3. Shelby Cobra GT500
    Latest Threads: 09-26-2005, 06:50 PM
  4. 2007 Shelby Cobra GT500
    Latest Threads: 08-15-2005, 09:24 PM
  5. 2007 Shelby Cobra GT500
    By NickGT in forum Automotive News
    Latest Threads: 03-27-2005, 09:05 AM
