Installing on two partitions - Beyond.ca - Car Forums
Results 1 to 20 of 24
Thread: Installing on two partitions
    Mar 2005
    Ford Escape
    Default two hard drives
    Hello:
    My laptop has two hard drives both 30GB.
    My question is any suggestions on installing programs and the operating of the computer. So I keep games and music on one drive and the other just the main windows components?
    Thanks
    Jul 2002
    Some wedges.
    That's the way it should be done. OS/software on one drive/partition and games, music, important shit on the other drive. That way if windows shits the bed, you're not left sitting in it. Format first drive/reinstall and everything's fine again (though you'll have to reinstall most of your software anyhow)
    WTB:
    87+ AW11 ds valence panel, ds fender, rear visor. Burgundy interior parts as well.
    7th gen Celica antenna assembly
    Please PM me, thanks!
    Dec 2004
    W204
    There are 2 issues here: 2 physical drives and 2 partitions. To me, it makes no sense to have 2 drives in a laptop since that'll just drain the battery like crazy. Just trade both in for a 60GB or something.
    As for 2 physical drives, I don't even think you need 30GB for Windows and programs. I usually get by fine with about 15 for Windows/Programs. Partition the rest of it to store documents or backups.
    Mar 2005
    Ford Escape
    Thanks for the help
    A laptop with 2 hard disks? Sounds like 1 drive, 2 partitions to me.
    Control Panel -> Admin Tools -> Computer Management -> Disk Management. That'll show you if it's 1 physical drive or 2.
    FYI if it IS only 1 drive, and you go to reinstall windows, make sure the setup program doesn't format/partition automatically or it'll erase your "work" drive. Sux.
    Left Coast
    Audi
    You can go right to the Computer Management console in Windows XP by right clicking on "My Computer" (on the desktop) and clicking Manage.
    It's unlike the NB has 2 drives... I know there were options for multiple drives (even RAID) on Sager/PC Torque and Eurocom notebooks - however those aren't the most mainstream notebooks
    Mar 2005
    Ford Escape
    Well now i feel dumb, yeah your right it is one drive which has been partition. Is this smart should I leave it the partition or format so it is just the one drive?
    Thanks
    Avalanche/Nightrod
    ^I would leave it partitioned since the computer will be a little faster if you keep things seperate. If the partition is on the same drive it shouldn't do anything to your battery life. I actaully create even more partitions to keep the computer organized: 1 each for windows, music, movies, docs. I use partition magic btw.
    Jul 2002
    Some wedges.
    Toshiba isn't mainstream?
    WTB:
    frostyda9 Guest
    I format the C: partition to a size of 7GB usually. This gives you room for Windows and core apps and a couple GB to spare. That would leave you with 51.5 GB of free space for everything else, which should be lots.
    Dec 2005
    Sorrow
    Hatred
    7g wow thats low. I always leave my primary as having something around 20g that way there is never going to be a situation were your drive could even possibly come low. Also depending on your virtual memory its always good to have tonnes of room to allocate to that as well.
    -U
    Vancouver
    yeah 15-20 is a gd value for the OS
    as for virtual, there are many theories
    but the general idea is to set it as a predetermined value, both max and min the same
    i do amount of ram x 1.5, and anything beyond 1 gb just the same number
    having 2 partitions is a gd idea because in the event that you have to reformat, all your data will be intact and you won't have to move anything around
    Dec 2005
    Sorrow
    Hatred
    The best idea for VM is to set it on a different hard drive as the OS. this usually doesn't apply to laptops but then the virtual can access faster while critical OS files are being access as well.
    -U
    Left Coast
    Audi
    I was just saying the Sager/PC Torque units are not the most mainstream ones. Toshiba is very mainstream - however I believe only the one toshiba line has it
    frostyda9 Guest
    15-20 is way more than you need for a system partition. Personaly I like to keep it small because it's fast and easy to maintain. The virtual memory (page file) doesn't have to be on the primary partition, either. If you have enough RAM, you can even turn it off
    Here's how my 7GB partition looks:
    Vancouver
    i can't confirm the turning it off part, but from what i read you need at least 50mb, or cheat windows that you have some
    it's tru that the swap doesn't have to be on the primary partition, but if you intend to have one, it's recommended that it's at the beginning of the drive (usually the primary), some even make a separate 'ram' drive at the beginning of the hard drive
    if you have one single hard drive and 2 partitions, you make no improvements by moving the swap to the second partition, because it's still the same harddrive
    it may be easier to maintain that way tho, because it won't be fragmented as much (provided that swap is the only thing on that partition)
    i will give that no swap thing a try tho, i already have 2gbs ram in my pc
    and 7gbs man? with the OS, office, premiere, photoshop, and just half life 2 that's almost gone
    Dec 2005
    Sorrow
    Hatred
    Having no VM isn't the best way to go at all. Windows has critical apps that store to VM by default and it actually can slow performance as windows realizes it doesn't exist and then has to try to store else where.
    -U
    frostyda9 Guest
    It can be done without VM, whether or not you want to try it is up to you. My system didn't slow down at all.
    The apps you mention at the end of your post don't need to be installed on your primary partition. When I say system, I mean SYSTEM. Programs, games, and media can all go on other drives. The only exceptions for me are anti-spyware and a few other programs like CPU-Z, Sandra, 3DMark, and Aquamark.
    So simple
    Vancouver
    so what happens to your programs if you choose to install a new OS or reformat C?
    frostyda9 Guest
    Nothing happens to them. They are on a separate partition...they will still be there after you format.
    All you have to do is re-target your shortcuts or direct launch
    from the respective program folders.
  1. FS: two wheels and two tires
    By prophet_ca in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 07-12-2004, 04:42 PM
  2. Need Some Help Installing a Xenon Kit...
    By Weapon_R in forum Mechanical
    Latest Threads: 09-19-2002, 09:48 PM
  3. Installing Decks?
    By Eagle Eye in forum In Car Entertainment / Electronics
    Latest Threads: 08-08-2002, 01:34 AM
  4. installing clear tails...(EK HB)
    By eur0 in forum Mechanical
    Latest Threads: 07-14-2002, 12:15 AM
  5. Installing New Gears?
    By Weapon_R in forum Performance Modifications
    Latest Threads: 06-20-2002, 01:31 AM
