For those who don't know DNP has uncountable uses in medicine, the best grey market fat burner there is barring a knife, as well as various industral uses, new studies on it come out all the time to try and find even more uses for it, these three I found to be kind of interesting
J Neurotrauma. 2005 Oct;22(10):1142-9.
The uncoupling agent 2,4-dinitrophenol improves mitochondrial homeostasis following striatal quinolinic acid injections.
Korde AS, Sullivan PG, Maragos WF.
It is now generally accepted that excitotoxic cell death involves bioenergetic failure resulting from the cycling of Ca2+ and the generation of reactive oxygen species (ROS) by mitochondria. Both Ca2+ cycling and ROS formation by mitochondria are dependent on the mitochondrial membrane potential (Deltapsi(m)) that results from the proton gradient that is generated across the inner membrane. Mitochondrial uncoupling refers to a condition in which protons cross the inner membrane back into the matrix while bypassing the ATP synthase. As a consequence of this "short-circuit," there is a reduction in Deltapsi(m). We have previously demonstrated that animals treated with the classic uncoupling agent 2,4-dinitrophenol (DNP) show significant protection against brain damage following striatal injections of the NMDA agonist quinolinic acid (QA). In an effort to elucidate the mechanism of neuroprotection, we have assessed the effects of DNP on several parameters of mitochondrial function caused by QA. The results presented herein demonstrate that treatment with DNP attenuates QA-induced increases in mitochondrial Ca2+ levels and ROS formation and also improves mitochondrial respiration. Our findings indicate that DNP may confer protection against acute brain injury involving excitotoxic pathways by mechanisms that maintain mitochondrial function.
__________________________________________________ _
J Neurochem. 2005 Sep;94(6):1676-84. Epub 2005 Jul 25.
The mitochondrial uncoupler 2,4-dinitrophenol attenuates tissue damage and improves mitochondrial homeostasis following transient focal cerebral ischemia.
Korde AS, Pettigrew LC, Craddock SD, Maragos WF.
Ischemic stroke is caused by acute neuronal degeneration provoked by interruption of cerebral blood flow. Although the mechanisms contributing to ischemic neuronal degeneration are myriad, mitochondrial dysfunction is now recognized as a pivotal event that can lead to either necrotic or apoptotic neuronal death. Lack of suitable 'upstream' targets to prevent loss of mitochondrial homeostasis has, so far, restricted the development of mechanistically based interventions to promote neuronal survival. Here, we show that the uncoupling agent 2,4 dinitrophenol (DNP) reduces infarct volume approximately 40% in a model of focal ischemia-reperfusion injury in the rat brain. The mechanism of protection involves an early decrease in mitochondrial reactive oxygen species formation and calcium uptake leading to improved mitochondrial function and a reduction in the release of cytochrome c into the cytoplasm. The observed effects of DNP were not associated with enhanced cerebral perfusion. These findings indicate that compounds with uncoupling properties may confer neuroprotection through a mechanism involving stabilization of mitochondrial function.
__________________________________________________ __
J Neurotrauma. 2004 Oct;21(10):1396-404.
The mitochondrial uncoupling agent 2,4-dinitrophenol improves mitochondrial function, attenuates oxidative damage, and increases white matter sparing in the contused spinal cord.
Jin Y, McEwen ML, Nottingham SA, Maragos WF, Dragicevic NB, Sullivan PG, Springer JE.
The purpose of this study was to investigate the potential neuroprotective efficacy of the mitochondrial uncoupler 2,4-dinitrophenol (DNP) in rats following a mild to moderate spinal cord contusion injury. Animals received intraperitoneal injections of vehicle (DMSO) or 5 mg/mL of DNP prior to injury. Twenty-four hours following surgery, mitochondrial function was assessed in mitochondria isolated from spinal cord synaptosomes. In addition, synaptosomes were used to measure indicators of reactive oxygen species formation, lipid peroxidation, and protein oxidation. Relative to vehicle-treated animals, pretreatment with DNP maintained mitochondrial bioenergetics and significantly decreased reactive oxygen species levels, lipid peroxidation, and protein carbonyl content following spinal cord injury. Furthermore, pretreatment with DNP significantly increased the amount of remaining white matter at the injury epicenter 6 weeks after injury. These results indicate that treatment with mitochondrial uncoupling agents may provide a novel approach for the treatment of secondary injury following spinal cord contusion.
