Fluid
How is the fluid level? have you checked it to make sure you arent leaking? It sounds like air has entered the system .. this is what I have used before and it works for me.
Manual brake bleeding is the most common method of bleeding brakes; however, you will need to enlist the help of an assistant. With your assistant sitting in the driver's seat, repeat the following six steps a number of times on each brake until you are sure there is no air trapped in the system. Use a narrow block of wood behind the pedal to prevent it from travelling all the way to the floor. Lastly, place a three foot piece of vinyl hose on the end of the bleeder screw to direct old fluid into a plastic container.
1.) Instruct your assistant to pump the brake pedal for thirty seconds
2.)Instruct your assistant to press and hold the brake pedal firmly
3.)Open a bleeder screw and let the air and old fluid escape
4.)Close the bleeder screw
5.)Instruct your assistant to release the brake pedal
6.)Wait fifteen seconds
Good luck!
-NATE
Wherever you go there you are
