hey i just put a new vtech engine in my 1996 honda civic but the problem is i dont no how to hook up the vtech like i hav the computer for it but dont no how to instal it can somone help me out
You need to run two wires for vtec. One to your vtec solenoid, and the other to the oil pressure sensor. The solenoid has only one wire, which you need run to pin A8 on your ECU. The oil pressure sensor has two wires, one which is grounded to the engine, and the other must be run to ECU pin C15.Originally posted by cipher
All you need to know about vtec/IACV wiring courtesy of FF-squad.com
Which engine did you put in? Some of the newer ones - I'm not sure exactly which ones - but my Type-R only had one wire for VTEC.
So if you're not using the ECU that belongs to the motor, you'll either have to tap your own oil pressure switch or find a new VTEC solenoid.
