open deck/closed deck - Beyond.ca - Car Forums
Results 1 to 16 of 16
Thread: open deck/closed deck
    oreo cookie
    a wrx.
    Default open deck/closed deck
    ive heard a ton of different explanations of what an open deck block is vs a closed deck block...still unsure.
    so....lets hear it from the tech gurus!
    closed/open deck refers to the way the cylinder sleeves are designed.
    dirty sohc's stock open deck d16
    b16 with darton closed deck sleeves
    see the difference?
    basically the cylinder heads are floating in a open deck design, and they are not in a closed deck design.
    Dec 2002
    CGY
    94' Terd
    whats the advantage?
    just more rigidty for high hp/torque apps er what?
    Jul 2002
    93 Prelude SR-V
    My h22a1 closed deck
    on the end of the img if you want to see a larger picture....
    the red outlining basically is trying to show you the wear against the bottom of the head, by the cyclinder head, due to the extra slop cause of no rod bearing.
    If you are pushing alot of boost you'll need thicker heavier sleeves put in that can take the increased pressure of the extra power. Closed deck is better for FI just for the fact that you dont have to worry about the cylinders shifting under pressure. If you want to stick with the open deck design then you might want to reinforce those cylinder walls somehow, like the B16's use the NuFormz block guard. But resleeving is the best option.
    Dirty_SOHC's Avatar
    Dirty_SOHC is offline 0.2 liters away from a good engine
    Jul 2002
    WRX
    Actually I have an STR block guard in there now.=)
    a van down by the river
    Bmw and ford
    from the pics post in this thread that is not block guard but dartan race sleeves.
    Bmw and ford
    IMO block guard is just plain ass and for low boost you do not need it and for high boost you need sleeves.
    Jul 2002
    93 Prelude SR-V
    redline that pictures states that it is darton sleeves.
    I know, I was just using a block guard as an example. I would not use a block guard.
    oreo cookie
    a wrx.
    and open deck is easier to cool i assume?
    It doesn't make a difference (assuming there are proper amounts of coolant passages on a closed deck block).
    Jul 2002
    944 535xi F250
    Open deck lets you use a permanent (reusable) mold. This also allows the molten metal to be pressurized for higher density. The casting is more accurate (less machining) and can be automated.
    Closed deck is done with casting sand which has to be cleaned out partlly by hand (expensive). The real reason for core (frost) plugs....not freeze protection.
    T2S
    pedals
    so how are the sleeves held in place on an open deck design?
    this is what my block looks like, closed deck i take it? Yes, closed.
    Oct 2003
    91 PP1 - 93 EH6 - 01 BB6
    Great explanation Alpine!
    Hjr they are attached lower down inside the block. IMO both designs have their pros and cons. I would think open deck designs would equalize sleeve temps slightly better than a closed deck, as the water jacket goes the length of the sleeve. Where as closed deck have a solid plate near the top, thus less surface area in contact with coolant to dissapate the heat. Anyone know what would design would allow more warpage?
  1. 951 vs WRX (closed road of course)
    By JustinL in forum Street Encounters
    Latest Threads: 03-09-2003, 09:49 PM
  2. open vs. closed face helmets
    By REFLUX in forum General Car/Bike Talk
    Latest Threads: 02-14-2003, 05:15 PM
  3. Replies: 15
    Latest Threads: 12-24-2002, 09:44 AM
  4. Thi Thi Vietnamese Subs has closed
    By FiveFreshFish in forum General
    Latest Threads: 12-18-2002, 08:11 PM
