Initial dyno of the H22/F20B turbo setup (XES) - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Initial dyno of the H22/F20B turbo setup (XES)
    Aug 2002
    Canada
    Black rocket
    Thumbs up Initial dyno of the H22/F20B turbo setup (XES)
    Finally got everything organized and street tuned enough that I could head over to the dyno.
    The runs were made at 12psi on 94 octane pump gas with the stock internal coil ignition. I probably could have leaned on it a little more and upted the boost, but i'll just wait until C16 is in the tank (this is my daily driver...).
    Just thought I would update everyone on the progress. The car runs great and is much faster than with the old motor.
    Surprisingly, power loss is not very high at higher rpms (earlier runs were made up to 9500rpm - nice and smooth with the F bottom end and short stroke).
    It made 401whp and 307ft/lbs @ 12psi.
    I don't have a scanner, so I just took a picture of the monitor.
    For all the detailed setup information go to www.preluderacing.com
    XES
    H22A/F20B S372turbo (800+whp)
    Nice numbers Brad!
    9500rpm is crazy. I felt like my motor was going to explode when I revved it that high.
    Nice numbers man....
    is that a/f graph accurate? Possibly could do some more fine adjsutments to flatten out that line a bit.
    Sep 2005
    1996 Mazda MX-3
    WoW man nice numbers. 9500RPM is insanity man!!!
    Feb 2003
    Calgary, Regina
    99 Civic Si
    wow, i like 9500 rpm, too bad i can't go that high
    91 PP1 - 93 EH6 - 01 BB6
    Good going man.. I knew those F20 bottom ends were a sure thing by their numbers. 1.65R/S FTW!
    What headgasket are you using if you don't mind me asking?
    Jul 2002
    2008 CSX Type S, 2008 BMW 335I
    i was scared! i was watching the tach go to 9000rpm and i was thinkin in my head...OMG when is this guy gonna let off.....sooo scary LOL!!!
    GET A NEW WIDE BAND and then you'll know what's wrong with you car!!! LOL
    GOOD STUFF FINALLY!!!!!
    Aug 2002
    Canada
    Black rocket
    OEM h22a4 headgasket. I am using a 87mm bore piston (not the standard 85mm F20B bore).
    XES
    Ah yes, that is definetly the way to go. I was thinking of building one of these beasts myself for my next turbo motor. Reduced side loads, rod bearing stresses, and increased top end power.. Whats not to like?
    Excellent job, you should post this stuff up on H-T in the prelude section if you haven't already.
    Dec 2003
    ^^ how hard is it to remove the secondary butterflies in the intake manifold?
    Aug 2002
    Canada
    Black rocket
    The power and torque difference is larger than u think compared to my h23/h22 setup from last year. The extra 50-75 ft/lbs of torque and additional power (increased spool up of at least 500rpm) would definately help out at the track. An open deck h22a4 would probably be the best of both worlds (exactly why Papadakis and other racers have been using those for years). I had a free f20b at my disposal and the reliability from the stroke doesn't hurt
    XES
    Aug 2002
    Canada
    Black rocket
    Very easy (just open it up and cut away)...and if you want to bore it out also that would be a good time.
    XES
  1. FS: Jdm Sir-t valve cover, Fits H22 and F20b
    By shadowz in forum Automotive Parts
    Latest Threads: 05-03-2004, 08:08 AM
  2. Honda Accord H22 vs Civic H22
    By david394 in forum Cars, Bikes, Machines
    Latest Threads: 03-03-2004, 02:24 PM
  3. 500+whp XES dyno pics, etc.
    By XES in forum General Car/Bike Talk
    Latest Threads: 01-16-2003, 05:48 PM
  4. XES turbo prelude for SALE (>500whp)
    By XES in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-04-2002, 04:18 PM
  5. Dyno update: So close but so far (XES)
    Latest Threads: 09-13-2002, 03:35 PM
