1. 6 disk honda/acura changer with trunk mounting bracket, 1 cartridge and cable. (used on 92 accord but good for other hondas and acuras) = 75.00 obo. SOLD
Small cracked piece, bottom left corner. Does not affect functionality.
2. 2 C10 Subs (used for ~10 months) and Amp Package - It's older gear but working perfect: $170 obo for the package...Last update 100 FIRM for 2 subs and amp!
> 2 Kicker C10's and a sony 3040 amp
Sub specs:
Model : Competition C10
Description : 10" Competition Woofer
Nominal Impedance : 4 ohms
RMS / Peak Power : 125 / 250 Watts
Sensitivity : 87.7dB
Frequency Response (HZ):30-500
Mounting Depth (IN., CM):4-9/16, 11.6
Mounting Hole Diameter (IN., CM)):9-3/16, 23.3
Min Rec Sealed Box Vol (CU. FT., LITERS):1.0, 28.3
Max Rec Sealed Box Vol (CU. FT., LITERS):2.4, 67.9
Min Rec Vented Box Vol (CU. FT., LITERS):1.25, 35.4
Max Rec Vented Box Vol (CU. FT., LITERS):1.75, 49.6
http://www.cardomain.com/member_page...97_41_full.jpg
Sony xm-3040 Amp info:
4 Channel: 55W X 4 @ 4 ohms,
3 Channel: 55W X 2 + 120W @ 4 ohms
2 Channel 120W X 2 @ 4 ohms.
8Hz à 100 kHz
Distorsion harmonique : 0,005%
40x4 RMS 4/3/2 channel amp. 2020000Hz 0.08THD
http://www.cardomain.com/member_page...97_55_full.jpg
PM if interested. Thanks
