Anyone have any recommendations for errr..bowel movement? Milk of Magnesia's making me want to throw up.
Exlax(sp?)
Fibre-1 Cereal.
Seriously. Ex-Lax is bad for you.
Colon Blow?
-U
over drink water for a day or 2
lots of banana's usually do wonders
or even the new yogurts with the probiotic culture in them (danone activia) works great so ive heard
After i had surgery and was taking a lot of codine nothing would make me go until i drank some seriously strong coffee. Its worth a try.
Sometimes the easy solution isnt a drug.
[SIZE=4.5]AWD BURNOUT![/size]
My morning coffee always triggers the beast within.
-U
Caffiene is a drug...and a diureticOriginally posted by Canadian 2.5RS
WTB:
87+ AW11 ds valence panel, ds fender, rear visor. Burgundy interior parts as well.
7th gen Celica antenna assembly
Please PM me, thanks!
Yeah I know but I was referring to the kind you go out and buy at the pharmacy.Originally posted by Ashkente
A bran muffin, Large coffee and a cigarette will keep you flowing.
prune juice
Metamucil
ice cream, hot wings, 25cent candy from 7-11 and beer.
ya...ex-lax is bad for you...
and the winner is: Morning coffee with a Granola Bar!! Man..I never knew shit smells worse after it's been fermenting. Pheewww.
more fruits and vegetables..
coffee, brans, and a smoke also help.. but don't smoke if you already don't
Curse you imageshack..
Exercise helps too. Go do something active like running or swimming or even walking.
a little late but i heard that drinking strong coffee and eating lots of jalapeno peppers at the same time does wonders. Buddy also told me that if I do this I should do it on the can or very close to it!
Ultimately, you must find your own unique path, your own unique plan. While you may share goals with others, you should not confuse what is required from you to achieve those goals with what is required from others to achieve them. Learn from them, and avoid the obvious mistakes that they make. But never get bogged down in a futile comparison, or use relative disadvantages as an excuse for utter lack of determination and commitment. - John Berardi
~0.0~ werd
get a tin of skoal... seriously, if you can hold the throwing up donw (if you dont chew) then the nic shits will totally get to you man
when cut open, the rambutan unfortunately fails miserably to deviate from its outwardly testicular appearance, revealing an inside that looks for all the world exactly how you'd expect the contents of a scrotum to look.
