AWD dyno in calgary - Beyond.ca - Car Forums
Results 1 to 13 of 13
Thread: AWD dyno in calgary
    Fuji's Avatar
    Fuji is offline Track Events Co-ordinator
    cars
    Default AWD dyno in calgary
    I ran on the AWD dyno iat Reigel tuning in calgary yesterday. Made an uncorrected 274/297 at 16.4 psi after 20 runs (so i was pretty heatsoaked).
    Hima and Casey were great and the dyno was a dynapack 3000. I had a pretty good time! If you guys are interested in running on it give Hima a call.
    Not Aspen
    Two from Freemont
    I thought you were trying to run 20+ PSI
    Fuji's Avatar
    cars
    I didnt set up my boost controller right. I need to configure it and then tune again, but you are right I am planning to hit 20psi
    Jul 2002
    So dynapacks for FWD read higher than dynojets. Closer to flywheel. Is this the case with AWD as well? I wouldn't mind getting a base line on my car before any mods.
    Fuji's Avatar
    cars
    no. dynapack reads lower than dynojet.
    To be honest it all depends on how they are configured.
    Hima was saying they rana car on the dynojet at davenport and it read higher than on thiers.
    '21 F150 Lariat Nardo Grey
    Funny, someone tried to setup the dyno day there and they said they only deal with Porsche.
    Good numbers though, J!!
    Dynapacks definately read lower numbers than a Dynojet. I'd say they read similar numbers to a Mustang dyno.
    Dynapack is supposed to be the most accurate dyno. Generally it reads between mustang and dynojet numbers.
    Jul 2002
    From all the dynapacks i have seen they read Higher than dynojets. There's no wheels or tires to drive so I figure they would be less loss. Closer to flywheel.
    TRD Pro
    Any idea the cost of a few runs?
    I had no idea there was a AWD dyno in Calgary... wonder if there is enough interest for a dyno day... Im sure between the Subie's, Audi's, and whatever else we could set something up
    From the Dynapacks I've been on and seen in person, numbers have always been between Dynojets and Mustang dynos. I guess it could just be calibration.
    Jul 2002
    yep, i suppose you can make these things read different things depending on setup.
    as fas as dyno day I'd be up for a base run for sure.
    Dec 2003
    In the dark
    I think the dyno in Edmonton is $50 for 3 pulls in 15 minutes for a baseline.
  1. For AWD people. New Dyno in BC
    By benyl in forum General Car/Bike Talk
    Latest Threads: 10-04-2005, 04:49 PM
  2. Dyno Conversion? *Includes Dyno Sheets*
    By boostless in forum Mechanical
    Latest Threads: 06-23-2005, 12:01 AM
  3. AWD dyno
    By ACURA dreamin in forum Mechanical
    Latest Threads: 04-08-2005, 02:37 PM
  4. AMG factory AWD dyno
    By rage2 in forum Cars, Bikes, Machines
    Latest Threads: 09-09-2004, 11:03 PM
