I have one extra hood-fenders-mirrors kit in stock, 200 installed.
btw: Its not the "3M" product, we use avery which is alot better.
Adam@Platinum AutoDetailing
403-203-4777
How is avery alot better??? Is that fact or opinion.
It's opinion BUT,
3M rockguard uses a topcoat which has tendancy to turn yellow after a few years, avery does not use a topcoat so it will never change colour
3M can't be wrapped around sharp corners, so on your hood for instance it can't be wrapped around the front edge to protect from rock chips. It has to be cut before the edges on the hood.
Avery has no problems wrapping around corners so the front of your hood will be protected
In my opinion that stuff is important and makes it a better product
3m can be wrapped around edges. and suprise suprise, averys NEW product HAS a topcoat.... the topcoat is what prevents yellowing......
3m product is far easier to use, easier to stretch, and last a lot longer, i pulled avery product off a 06 murano... it was ALREADY turning yellow.....
and btw, ppf is the same as regular car finishes, in order to keep the clean, "yellow" appearance from occuring, you have to treat it like paint, regular waxing etc..
(not trying to be a dick, Just stating information)
