What can cause an extreme amount of smoke from the exhuast? I know it's not oil, it may have something to do with the coolant. I check a couple things, the coolant is a little high, other than that i'm not too sure.
Thanks
Thanks
What color?
Current Cars:
2004 GMC 2500HD 8.1L
Past Cars:
1970 Chevy Blazer, 2wd
2005 Jeep Wrangler LJ
1989 5L Mustang
1990 Jeep Cherokee
I'm not too sure i didn't see it, i'm actually thinking the head gasket went. I could smell it when i sat in the car, seemed to smell a little like burnt coolant.
If the coolant level in your reservoir is high, it could be a headgasket leak. Also, if the smoke exiting your tailpipe is a lingering, white smoke, this is also a sign of a headgasket leak....
Yeah, my sister stoped at a gas station and they said the car could probably disapper in the smoke.Originally posted by cocoabrova
Is this in the Prelude?? If not, then what kind of car? Most likely my diagnosis is correct, if it's blowing white thick smoke....
haha no not the lude, my sister car a 93 olds cutlass convertible.
Originally posted by kaput
I'm pretty sure white smoke = burning coolant and blue/black smoke = oil.
Black smoke can be carbon burning up in your exhaust system too...... like when you goose your moms mini-van that has never been past 3000 rpm and you see a big cloud of smokie... thats carbon build-up being shot out your exhaust system.
If you have huge amounts of smoke though it is most likely coolant..... huge amounts of black smoke would only last a few seconds before the engine siezed, due to no lube inside your cylinders.
"I believe that banking institutions are more dangerous to our liberties than standing armies. If the American people ever allow private banks to control the issue of their currency, first by inflation, then by deflation, the banks and corporations that will grow up around the banks will deprive the people of all property until their children wake-up homeless on the continent their fathers conquered."
-Thomas Jefferson 1802
same problem with my crx. mad amounts of white smoke. so i replaced the head gasket, and the problems gone.
Bluish smoke=oil burning, needs rings
Black smoke=rich condition
White smoke=headgasket leak.
None of these are particularly good...
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
Let the car idol, smell the exhuast and if it burns your eyes that's coolant burning for sure.
Hey if it is BLack smoke make sure that she has't put like an extra few litres of oil this to will create Alot of Smoke! Empty the oil pan to check!!! Just do oil change!
im pretty sure exhaust if you hold your face close enough no matter what youre burning will burn your eyes...Originally posted by ls/vtec-crx
smoke coming out of the exhaust means the car is running. STUPID!!
Holy chit!!! you should be a professonal mechanic Buh_buh!!!. Man i should get you to look at my car, when i brake i find the pedal very hard, according to you the pedal is supposed to touch the floor when you brake. You think i should add more air in the lines??? :tongue:Originally posted by buh_buh
Now, if the smoke turns into flames, then you or your car has seen too many reruns of F&F...
haha alright man, I guess your car is worthy for me to work onn. hm.... ok, I think I've figured it out, you need to buy a big brake kit, give it to me, and I'll swap out my stock ones just for you.Originally posted by 5gluder
I changed my mind, stay away from my car. Calgary dosen't need another lude that looks good but don't runOriginally posted by buh_buh
yeah, that's true. My car is just for show.... haha. Actually I think I'm slower than stock. Let me drive your car and compare. hahahOriginally posted by 5gluder
