Physics Question - Water fallout from flowing gas?
I'm considering working on a project here.
The Scenario:
- a piece of horizontal pipe is flowing gas and water through with a known inlet and outlet pressure. Pipe rougness is known.
- the gas(CH4) and water rates are know as well as their density
- at the beginning of the pipe, all the water is suspended in the gas due to the velocity, pressure, temp, etc of the conditions that the gas is flowing at
- as the gas and liquid flow along the lenght of pipe, a pressure drop is experienced from frictional effects of the pipe wall.
- as pressure drops along the length of pipe, the gas velocity increases due the it being less dense.
- the temperature also drops as the pressure drops down the length of pipe
- as the conditions along the length of pipe change, the ability for the gas to suspend and carry the water changes. Water may begin to drop out of the gas and collect on the floor of the pipe
I'm able to predict the pressure and velocity along the length of pipe, as well as a rough temp. This model assumes all gas + liquid that enters also exits.
![click for larger version](http://i18.photobucket.com/albums/b109/Ekliptix/liquid-dropout.jpg)
Objective:
- predict liquid fallout along the length of the pipe
Other Notes:
- I think a phase diagram, or some other info describing the potential for the gas to absorb water at different conditions is required.
- This is the minimum velocity required to suspend water in a vertical pipe:
![](http://i18.photobucket.com/albums/b109/Ekliptix/Vwater.jpg)
A = cross-sectional area of flow (ft2)
G = gas gravity
k = calculation variable
P = pressure (psia)
qg = gas flow rate (MMscfd)
T = temperature (R)
vg = minimum gas velocity required to lift liquids (ft/s)
Z = compressibility factor (supercompressibility)
Any ideas?
Current Cars:
2004 GMC 2500HD 8.1L
Past Cars:
1970 Chevy Blazer, 2wd
2005 Jeep Wrangler LJ
1989 5L Mustang
1990 Jeep Cherokee
