FOR SALE: 1990 Pontiac and 1991 Chevrolet Corsica
Located in NW Calgary, AB
$1500 for the lot (negotiable). Both vehicles including parts are sold as-is, where is.
Details:
'90 Tempest - Perfect winter beater!:
• Low mileage (166000 Kms) and in great mechanical shape.
• Includes all repair records from the last 3 years, ’90 GM Factory Service manual, and three Haynes repair manuals
• Motormaster Eliminator Battery with 3 years remaining on the warranty
• Suspension (front and rear) struts and shocks replaced
• Ball joints replaced
• CV boots and CV joints inspected and repaired
• Transmission flush and filter kit
• Fuel filter replaced
• Aftermarket K&N air filter
• Regular, frequent oil changes every 5000kms or 4 months.
• EGR valve replaced
• PCV valve replaced
• O2 sensor
• NGK Platinum Spark Plugs + Bosch wires
• New Front brake discs, calipers and fluid change
• Rear brake drums serviced
• Coolant flush and fill
• New tires
• Power steering system rebuilt
• Steering column ignition rake replacement
• Thermostat and pot-steel heater fittings replaced
• Fuel injectors and carbon buildup service
• Timing Chain inspected
• Accessory belt replaced
• All bulbs checked and replaced
'91 Corsica:
• A parts car with an excellent body with no rust
• excellent body panels, glass and light assemblies
• Has a seized engine that may be repairable and plenty of peripheral engine parts
• (The Chevy Corsica is the 'sister' model to the Canadian built Pontiac Tempest.)
Bonus! -- I am also throwing in:
• 4 sets of tires in various shape. One set is a rare Berretta GTZ alloy rim set with very good tread left, currently on the Tempest
• Spare gaskets that were not previously installed
• Other miscellaneous parts, repair pieces, and tools
