Specifications:
Top of the line alarm with two way remote pager with a range of 3000 feet. Works on 900Mhz FM frequency. Can be installed on any type of car. Compustar comes with Lifetime warranty if there's something wrong bring it back to Autotemp Calgary and they'll get it fixed within a week or so. Retail value $599.99.
Lightly Used.
The box contains:
CM3000 BRAIN for Auto/ Manual Cars (just need a wire)
2W900FM-AS ANTENA (inside mount)
VPS KNOCK SENSOR (inside mount)
BLUE LED INDICATOR
2W900FM-AS REMOTE CONTROL
128DB SIREN
2 STAGE SHOCK SENSOR
INSTALATION AND PROGRAMMING MANUALS
WARANTY REGISTRATION CARD
Specifications:
- Includes dual stage shock sensor
- RPS (remote paging system)
- External Siren (six-tone)
- Super bright blue LED
- 2-auxillary outputs, expandable to 7 with Channel Expander
- Cold start with optional Temperature Sensor
- Dedicated trunk output
- Horn honk output
- Includes anti-grind and starter-kill relay
- Driver's priority unlock
- Ignition controlled door locks
- Trunk release output
- Diesel features built-in
- Manual transmission compatible
Basic Remote Features
- Two-way paging remote
- Vibrate and audible notification
- Run-time indicator
- Detailed icons
- Turbo timer or 2nd Car
- CompuGlow backlight
- Multi-color LCD (liquid crystal display)
- RPS on/off through remote
- Shock sensor on/off through remote
- Passive on/off through remote
- Valet mode on/off through remote
- Uses standard AAA 1.5 volt battery
- Built in Clock
- Largest LCD of any CompuStar remotes
- 2004 Innovation Award Winner
Asking $300
Can get it installed virtually anywhere from $150 to like $200ish?
Thanks,
Steve
