Survey for albertan residents (PLEASE help)
Hey guys, i'm doing a survey to gauge albertan views on oil sand development PLEASE HELP, it won't take more than a couple minutes. FOR ALBERTAN RESIDENTS ONLY PLEASE, all of this infortmation will remain confidential
for 1-10 questions 10=strong agreement, 1=disgreement
Questions:
1. Which best describes you? Male / Female
2. Are you a university student, or professional?
3. what is the extent to which you are aware of the economic, social, and environmental issues regarding development of Alberta oil sands (1-10)
4. Do you believe that global warming is a concern for our society today? (1-10)
5. Are you familiar with the factors that are linked to global warming, caused by oil sands development? Yes / No
6. Are you familiar with the term greenhouse gases? Yes / No
7. Do you believe that limiting and monitoring the emission of greenhouse gases is a concern? Yes / No
8. Do you believe that companies should be required to reduce greenhouse gas emissions that are responsible for climate change? Yes/No
9. Do you believe that conservation and maintenance of Alberta’s forest a major concern? (1-10)
10. Are you familiar with the local conservation efforts of the forest? (1-10)
11. Do you believe that the restoration projects that oil sand companies have planned for the forests affected by oil sand development is proficient to return the land to its previous state (1-10)
12. Do you believe that companies have done there part in returning the developed land to its previous states via these restoration projects up to date? Yes/No
13. Today in Alberta over 85% of the provinces boreal forest is open to industrial development, is this amount of forest available to much or to little by choosing between (1-10)
14. Should oil sand companies be able to use water from rivers (such as the Athabasca river) for bitumen processing Yes/No
15. Should oil sand companies be able to use water from rivers, under strict government regulations, in order to avoid fish habitat damage during low flow periods? Yes/No
16. Do you believe Alberta has enough protected areas, i.e. parts of landscape set aside as wildlife reserves? (1-10)
17. Do you agree that protecting our environment is essential, even if oil sand development is hindered? Yes/No
18. Do you believe wildlife such as woodland caribou should be protected even if this reduces opportunities for the development of oil sands Yes/No
19. Do you believe that oil sand development is essential to the Albertan economy? (1-10)
20. How important do you think oil sand development is for the future of Alberta (1 -10)
WAR IS PEACE
FREEDOM IS SLAVERY
IGNORANCE IS STRENGTH
