Does anyone know where the jack and jack stand points on a 2002 Accord are?
check pinch welds just behind the front tire and in fron of the rear tire. The older accords (and lots of other hondas) have a little arrow under the side skirt pointing to the jacking location.
Your owners manual shoudl tell you.
There's also jack points at the front and rear if you don't want to bother with those other ones.
Original Post Removed. (Please read the Forum Rules and Terms of Use before posting again, or risk getting banned).
I don't know about that^ Are you sure its not the floor pan?
I've actually seen this done before, when I wasn't watching someone start jacking, pumping away, wondering why it wasn't going up, open the door and floor is half way to the steering wheel...
