my windows are frozen, and i mean FROZEN - Beyond.ca - Car Forums
Results 1 to 20 of 23
Thread: my windows are frozen, and i mean FROZEN
    Aug 2006
    My Crotch Rocket
    Default my CAR windows are frozen, and i mean FROZEN
    the inside of my windows are iced, and i can use my finger nail to scrape it to chunks of ice/snow. What can i do to solve this? i think i can get the ice off if i use a blow dryer and blow it, but then it mite just freeze up again. Whats a good suggestion?
    Jan 2006
    Axis powers
    inside ur house?
    check for drafts on ur window panes and sills.. fix any cracks around ur windows, reseal.. also try lowering the humidity in ur house
    Sig nuked by mod.
    Nov 2005
    red slowpoke, black beast, red 4wheeler
    sounds like a single pane window. in that case nothing, might try a plastic film on it but i'm not sure if that will work
    Aug 2006
    My Crotch Rocket
    lol oppss...for got to mention its my CAR
    cause if its my house, it wouldnt matter, but im driving and its slippery already, and i cant see anything on the sides, and i cant even shoulder check, only the front and rear windows are frozen (completely) lol
    Feb 2004
    Edmonton
    cts-v, 03 envoy
    we had the same problems last year with our doul pane windows, all we needed to do is get them re-installed i gues it was sealing properly.
    May 2005
    2015 IS350 F Sport
    nevermind
    WRX STI
    Dont use the recycle air button, use the outside air, full heat, with air conditioning on.
    Aug 2006
    My Crotch Rocket
    i thought if u have AC on hwile heat full it will blow your AC
    Jan 2006
    Axis powers
    how do u use air conditioning and full heat at the same time?
    Sig nuked by mod.
    A/C is drier than the recirculated air. A few extra cents to run your air conditioner is worth the safety of being able to see out your window.
    If you let your car warm up properly inside before driving then it'll make a huge difference. If you don't, you might never get the condensation/frost off the inside of the windows.
    Dec 2004
    Calgary/Alberta
    simple, set the heat to full with the ac on. it will act to dehumidify your car. Works well in my cars.
    slower than you...
    WRX STI
    Yeah it de-fogs or de-ices the windows pretty quick. IN most newer cars if you set your dail to blow the air on the windows, it will automatically put on the ac button and you will see it light up. Thats the deal in my last acura and my 2002 honda anyway. It will blow hot dry heat.
    Jan 2006
    Axis powers
    my ac wont come on unless i have the temp setting at cold
    Sig nuked by mod.
    Oct 2004
    AB/NS
    I usually go start the car and set it to 2 out of 4 on the fan, with the defroster on the rear window and recirculation.. it runs that way for 5-10mins, then I go out grab the snow brush and crank it full blast, and turn off the recirc.... brush off the windows and it should be good to go, up to temp, and clear.. I find it bad when my gf gets in after a shower, the warm wet air off her hair steams shit up quick, so you have to keep that air going, the more air you move the less fog and ice will form. If you use the recirc air all the time, it will be moist from you, your breath and melted snow off the mats and stuff...
    WRX STI
    Yeah recirculation will warm up your car the fastest but once its warm you gotta quickly turn that off before it fogs like crazy. But ac and heat ftw.
    Apr 2004
    Torqueless wonder!
    Also, if your heater sucks, you might want to make sure you don't drive fast while it's still frosted up somewhat (or even at all, depending on the temperature inside your car).
    Over the past couple days, I started driving when my windshield had defrosted on the inside a little bit, enough so that I could see. But, when I started driving it froze up again almost instantly.
    CAlgary
    89 Colt Turbo
    theres solution that you can buy where you spray or wipe onto windows and acually helps to melt ice faster,also is awesom when raining
    Sep 2006
    Alberta
    FG Civic
    My car wont heat up at all unless i drive it. The temperature gauge will stay at one digit (its a digital readout), even if i leave it in the driveway on for 15 minutes. Its retarded. (2006 civic)
    Oct 2004
    AB/NS
    at what fan setting? if it's blowing wide open the whole time, it'll take for ever to heat up...
    Dec 2005
    2009 Forester
    This usually happens because you track in lots of snow and it melts in your floor mats, evaporates, and then freezes on the inside of the windows.
    try to remove as much snow as possible from your feet before getting into your car.
    what I also do is leave a window open a tiny bit to let the humidity out while the car is parked. this helps a lot.
    Tim
  1. blown zo6,whipple 03,TT 350Z and some mean F-bodies
    By Gripenfelter in forum Cars, Bikes, Machines
    Latest Threads: 07-30-2006, 08:03 PM
  2. what does ttt and bump and imo mean?
    By import_illusion in forum Suggestion/Comment Box/Forum Related Stuff
    Latest Threads: 12-10-2004, 10:36 PM
  3. FS: 17" Tenzor mean 6 rims and tires
    By mrphilly in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 10-08-2004, 10:16 PM
  4. FS: Windows 2K pro, Windows XP pro
    By FuzzyWuzzy in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-26-2004, 02:43 AM
  5. Replies: 4
    Latest Threads: 02-18-2003, 02:15 AM
