Where can I get an adapter for Component input and other output? - Beyond.ca - Car Forums
Results 1 to 17 of 17
Thread: Where can I get an adapter for Component input and other output?
    Nov 2005
    2015 Hyundai Veloster
    Default Where can I get an adapter for Component input and other output?
    My TV has every input except for component and I am trying to hook up my Wii and PS2 via the component cables. So I need to know if there is anything that will take a component video input and something like a DVI or HDMI output. Or maybe even VGA if there is no quality loss.
    Originally posted by Go4Long
    Originally posted by blitz
    957,958,NC1,NC3,E90,ITR
    dvi and hdmi won't work since they are digital and component is analog. if your tv has vga, you can try this cable from monoprice:
    http://www.monoprice.com/products/pr...ormat=2&style=
    i don't know whether or not it will work but it's only $2.86 so it won't hurt to try.
    Nov 2005
    Will there be any quality loss converting from Component to VGA?
    Nov 2005
    Wait, that cable is component output, I need component input.
    Mar 2006
    is300
    use a vcr?
    actually, after reading the description i don't know if this will work.
    This cable doesn't support a computer monitor video port, or Y , Cr, Cb Video. Your video source should provide a YpbPr Component Video Signal from the HD 15 video ports to use this cable.
    This cable can not convert the video signal from one type to another. Both devices must be compatible with the same signal. Do not assume that this cable will work just because you have a VGA port (ie. you can't use this cable to connect your PC to a device that only accepts component video, since PCs do not output component video).
    Dec 2003
    2011 Audi TTs
    Default Re: Where can I get an adapter for Component input and other output?
    ps2 and wii arent high def i dont think...will it make much of a difference using component?
    Bicycle
    Nov 2005
    Originally posted by Xtrema
    You'll need this:
    http://cgi.ebay.ca/HDTV-Component-Vi...QQcmdZViewItem
    and this for multiple inputs
    http://cgi.ebay.ca/4-1-AUDIO-AUTHORI...ewItem#picture
    No, that converts DVI to component. I need the other way around. They're not bidirectional.
    Sep 2003
    Try getting a AV Receiver with Component video switching. I think this is the third time I have said this to you. Many AV Receviers will have a component input. You can choose to output through component, Super Video, Composite and in many cases HDMI.
    Game Device -----> Component Cable ----> Receiver ----> Super Video Cable ----> Projector
    with a better A/V Receiver
    Game Device -----> Component Cable ----> Receiver ----> HDMI ----> Projector
    OR
    Game Device -----> Component Cable ----> Receiver ----> HDMI ------> HDMI to DVI Convertor ----> Projector
    There is a device that will Convert Component to DVI... though I dont remember where I saw it. I think its a better investment to just get a good receiver that does it for you and countless other stuff too. This way you can connect your dvd player, playstation, nintendo, cd player, ipod, computer and a bunch of other stuff right into your projector without having to switch up all the wiring.
    OR
    converting from component to hdmi isn't as easy as it sounds, it's analog to digital. most receivers will do composite/s-video to component output which is analog to analog. if you want to convert to hdmi you're looking at receivers above $1000. here's one on sale at FS:
    http://www.futureshop.ca/catalog/pro...0080050&catid=
    Bicycle
    Look again, that dongle goes into the DVI port on your TV an turn it into a component input.
    that adapter won't work unless his tv supports analog dvi inputs...
    Bicycle
    Yeah, that's the catch. DVI-I not DVI-D.
    If you want a true upscaler, you'll need something like this:
    http://store.pcpowerzone.com/vicotodvsc.html
    Nov 2005
    I asked one of the guys at Futureshop and as soon as I got the words component and input out of my mouth, he cut me off and said no. There doesn't seem to be any sort of machine, including receivers, that'll upscale from component to a digital signal like DVI or HDMI....at least not one for under $200. But I was told of a place here in Calgary called Alberta Computer Cable (www.cablesbyacc.com) who actually make Audio/video cables so if it exists, they should be able to make it. My only hope right now is a component to VGA converter which is the only way to get component input to the projector without signal loss and without $$$ loss. I'm going to try this ACC place Tuesday and see what they have, otherwise I have to return the projector and get an actual home theater one with component input like the HD72.
    Nov 2005
    red slowpoke, black beast, red 4wheeler
    ^^^ nice find on the shop for 20 bucks i am gonna go get one of those dvi - hdmi cables woot
    Feb 2004
    rental
    for A.C.C.
  1. where can i get hte cheapest component cables?
    By 5abi in forum Computers, Consoles, and other Electronics
    Latest Threads: 06-09-2006, 07:55 AM
  2. WTB: DVI to Component Adapter
    By duffy in forum Computer Hardware & Peripherals
    Latest Threads: 03-10-2006, 09:29 AM
  3. WTB: AC Input, DC Output power adapter\Charger
    By Bigwave in forum Computer Hardware & Peripherals
    Latest Threads: 08-07-2005, 01:25 PM
  4. Where can I get this Wire (RCAs on one end, Aux on the other)
    By Weapon_R in forum Computers, Consoles, and other Electronics
    Latest Threads: 06-16-2005, 12:17 AM
  5. small high output batteries, where to get them?
    By dymz999 in forum Mechanical
    Latest Threads: 05-27-2005, 07:59 AM
