alright so my engine is royally screwed and i've been trying to determine where the problem lies...hopefully someone can give me a point in the direction of where my engine problems lie. i have another DOHC ZC 1.6 (non vtec) engine and i'm trying to figure out if i just need to swap the head (if thats where the problem is) or swap the whole engine if need be
symptoms:
-burns oil like a bitch
-also the way it burns, at startup a bit of a puff comes out and then it eases off...kind of like bad valve seals and it burns pretty bad at high revs. also if u let it idle for a long time, again big plume of smoke like bad valve seals....
-at idle with the oil cap off exhaust comes out of valve cover
(now i'm no licensed mechanic but from my very limited understanding of engines i'm pretty sure you shouldnt have exhaust coming out of your valve cover when the cap is removed.)
-very hard to start (probably due to the WAY off valve settings. have to give it gas to slowly get it going and once warmed up its a bit better)
-something is warped so i cannot perform a valve adjustment
(this head was hydrolocked and rebuilt (cant remember exactly how many valves were bent) and now most are completely backed off as much as possible and no clearance between the camshaft lobe and the rocker
-block was from a previously turbo-ed setup, we only honed it and re-ringed it (yes i know i shouldve bored it out but at the time that's all i was able to get done)
now i'm trying to determine if the leak is coming from below or above. basically i think its either combustion gases are seaping past the rings and into the oil pan and then making it up to the head. but to me that seams hard if the oil pump uptake is submerged in oil.... (again based on my limited knowledge of engines) ....or if the block and rings are fine and the problem lies only in the head and valves and oil is dripping into the combustion chamber... then all i have to do is replace the head and i'm sitting fine....
also if anyone can recommend a place to get a cheap leakdown test done or help me do one, would be greatly appreciated.
thanks for any thoughts or help
