Does anybody know how to remove the brake disc on a 2002 Xterra? Any help would be appreciated thanks.
If your talking about the rotor, there should be a couple bolts on the back of the caliper. Take those out, and the caliper should slide right off, once it is off the rotor should easily slide off the studs.
In a typical setup yes. However, there is another stud with a cap in front of the rotor. Removing the cap reveals the end of the drive axle - I have no idea how to remove the stud and cap in front of the rotor
