Dot 3, Dot 4 - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: Dot 3, Dot 4
    May 2003
    Proton Wira 1.5 GLi
    Default Dot 3, Dot 4
    Hi.
    On my car's brake fluid reservoir cap, it states "Use DOT 3 or DOT 4 fluid only". So, which do you think is more recommended for my car? Is it DOT 4, as it has a higher dry and wet boiling point?
    Apart from that, what are the colors of DOT 3 fluid and DOT 4 fluid? I read that it is not recommended for us to mix DOT 3 and DOT 4 fluids right? If so, what are the colors of DOT 3 and DOT 4 fluids, so as to allow me to add the same type of fluid?
    Besides that, I always read that we must fill the reservoir with brake fluids from a sealed-container. If the brake fluid level drops a bit (but not too much, and not enough for me to fill in an entire bottle of brake fluid), what should I do? Leave it alone? Or fill it until full, then dispose the remaining fluid?
    Thanks!
    Aug 2002
    RX-7/92 toyota pickup
    I would also like to know about this too. I asked some mechanic today about putting in dot 5.1 fluid and he siad that it was a bad idea and I can only use dot 3. Why would it matter since the boiling point is just higher?
    T2S
    pedals
    mainly the only differency is the heat caqpacities. Dot 4 can get hotter than dot 3, and so on. Also, i think that a car with ABS needs dot 3 to 4 for some reason.
    Aug 2002
    Generally 3 and 4 are interchangeable. You want to avoid Dot 5 which is a silicone-based fluid and not that great for the seals... I've heard that 5.1 is non-silicone but I have no experience with it.
    As for the color, my last batch was clear out of the bottle. The color doesn't mean anything, other than it's probably time for you to change the fluid! :tongue:
  1. Good place for DOT helmets???
    By darknight in forum General Car/Bike Talk
    Latest Threads: 04-04-2003, 05:55 PM
  2. Nitto Tire Dot Com
    By raab in forum General
    Latest Threads: 08-30-2002, 11:30 PM
