Usually there is only 1 or 2 GFCI circuits in the entire house. In the house we just built, the GFCI circuit in the master is shared with the one in the main floor 1/2 bath and upper main bath. So if the circuit trips in the ensuite, I have to run to the upper main bath to reset it. So it should be running off the same circuit (should just be a wire from the counter outlet and an additional electrical box).But then again, maybe they do have a add something special to it.
I am not too familiar with condos though. Just ask them what they're installing. If it's just wires and a box, then yah you're getting jacked. If it's a seperate circuit, then it sounds right.
What the heck do you need another plug by the toilet for?? Want to put a TV there?
