Found out what's under the hood and what the interior looks like. For more pics you can check out the thread on the 2nd page of this forum.
The Lamborghini V10 cylinder DOHC four valve V90 5 liter, 500 Hp, 510 Nm, is the concept solution for the high performance Gallardo. Instead of the more classical choice of a V72, an angle of 90 degrees was preferred in order to limit the height of the engine with advantages in the car layout (e.g. lower engine bonnet and better rear view) and in the lowering of the centre of gravity (i.e. better car dynamic characteristics). Even firing intervals (that ensure the smoothness of the engine) are guaranteed by the adoption of crankpins incorporating an 18-degree offset. A dry sump lubrication system not only achieves the correct lubrication even in extreme dynamic conditions, but also permits the centre of gravity to be lowered further. The throttle control is performed via a Drive by Wire system, with two electronic throttle bodies.
The main feature is the permanent four-wheel drive transmission, based on the well-proven Lamborghini Viscous Traction system. The gearbox is 6 speed, using of the latest generation double and triplecone synchronizers and optimised actuation linkage in order to achieve precision and velocity in shifting while ease of operation is guaranteed. A robotized sequential gear shifting system, the Lamborghini e gear, has also been developed, maintaining the basic mechanical gearbox unchanged.
Together with the perfect definition of suspension, weight distribution, centre of gravity and aerodynamic characteristics, the achievement of high body stiffness is fundamental to obtain optimal car dynamics and driving enjoyment even on long trips. For the Gallardo Lamborghini engineers have chosen to utilize the aluminium technology developed by AUDI, world leader in this field.
The choice of double wishbones front and rear suspension system, true to Lamborghini engineering tradition and a must for high performance sports cars, has been confirmed also for the Gallardo. The accurate definition of the geometry, of the characteristics of springs and stabilizing bars and the adoption of Koni 'selfadjusting' FSD dampers have been fundamental in achieving the desired handling, high speed stability and comfort performances. In addition to the optimisation of the suspension characteristics, a must was the definition of the correct aerodynamic features, by concentrating not only on the reduction of the drag coefficient, but, even more important, on the control of the front and rear lift coefficients. Such a study lead to important aerodynamic body refinements (e.g. front flap, flat bottom) and to the implementation of a rear spoiler, electronically controlled as a function of the vehicle speed.
